Brother MFC 210C All-In-One InkJet Printer Logo
Posted on Jun 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to send fax
How do I send a fax. Step by step directions would be great. thank you
Michelle
Anonymous
Level 2:
  • Expert 88 Answers
  • Posted on Jun 24, 2009
Anonymous
Expert
Level 2:
Answers
88
Questions
0
Helped
44291
Points
223
1. if it's not already green, press the Fax button
2. load your document
3. enter destination fax number
4. press the Black Start button
5. press 2 to start dialing
6. press Stop/Exit button to cancel fax
Hi My sons Asus X58L will not log on. I am the admistrator and his mum. It just keeps showing as failed. The only other strange thing is there are two zz buttons lit up, not sure what they are I can't...
hi michelle can you and your mum login in still? if you can you can go into his logon details and change them and try again this should fix the problem.
all you do is step 1 click start when you login on
step 2 click on the link to the control panal
step 3 click on users accounts and family safety you with me?
step 4 click on user accounts there you should fine all login files
step 5 click on your sons and change the password there your done now log out and see if it work
2helpful
How to fax from a samsung fax machine
hi friend,
Step 1Create a cover letter to use saying who the document is for and from as well as the intended fax number and your phone number. This alerts the office or home the fax is sent to who it is intended for. Place cover letter on top of your documents and insert them into the fax machine feeder facing in the direction the machine specifies.
  • Step 2Enter the fax number into the machine. There will be a number pad just like a phone on the fax machine. Carefully type in the number so you do not make any mistakes, as it is difficult to know when you have dialed a wrong fax number.
  • Step 3Hit the send key once you have properly entered all of the numbers into the machine. This will initiate the sending of the documents. The send key should be larger than the others and easy to locate. Traditionally, it is placed next to or below the keypad.
  • Step 4Wait for your documents to pass through the machine and collect them when finished. Whatever you are sending will pass through a series of rollers that feed it through the machine and copy it digitally.
  • Step 5Look for a confirmation page to print. This will tell you whether or not your fax successfully went through.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); })hope this helps u
    please rate me....................
    thak u for using fixya
    regardsa
    sivaranjini
    5helpful
    I wanna send a fax
    Sending Faxes.
    * Flow of Sending Faxes.
    The operation flow of sending faxes is as follows.
    Step 1:
    Load the original to send on the Platen Glass or the ADF.
    Step 2 :
    Adjust the fax quality and scan contrast.
    Step 3 :
    Dial the receipent' s number.
    Step 4 :
    Send Faxes
    - Using the Platen Glass
    1) Press the Color or Black button.
    If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
    2) After scanning all the pages of the original, press the OK button to send the fax.
    - Using ADF
    The fax is sent automatically.
    * Before sending Faxes
    - Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
    ** Adjusting the Scan Contrast
    Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
    1) Press the FAX button, then press the FAX Quality button.
    2) Press right or left arrow ot select the contrast.
    Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
    3) Press the OK button.
    ** Adjusting the Image Quality (Fax Resolution)
    You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
    1) PRess the FAX button, then press the FAX Quality button two times.
    2) Press the right and left arrow keys to select the resolution.
    FAX RESOLUTION - STANDARD
    Standard : Suitable for text-only documents.
    FINE : Suitable for fine-print documents.
    PHOTO : Suitable for photographs.
    *Sending Faxes - There are 4 methods for sending functions
    a) Memory sending
    b) Manual sending
    c) Dialing the coded speed dial
    d) Redial
    a) Memory sending
    1) Prepare for faxing
    a) Turn on the machine,
    b) Load the original on the Platen Glass or the ADF.
    Note : You cannot scan double-sided documents from the ADF.
    c) Press the FAX bitton.
    d) Adjust fax settings as necessary.
    2) Start faxing.
    a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
    b) Press the Color button for color sending, or the Black button for black and white sending. I
    c) When the following message is displayed, lad the next page on the PLaten Glass.
    Scan Next -> Start
    Transmit-> OK
    If only one document go to step f).
    d) Press the same button as you pressed in step b).
    e) Repeat step c) and d) to scan in all pages of the document.
    f) Press the OK button.
    Manual Sending
    1) Connect a telephone to the machine.
    2) Prepare for faxing.
    a) Turn on the machine.
    b) Load the original in the ADF,
    c) Press the FAX button.
    d) Adjust the fax settings as necessary.
    3) Lift the handset of the telephone connected to the machine.
    4) Dial the receipient's number on the telephone.
    5) Talk through the handset to the recipient.
    If you hear a high-pitched signal instead of the recipient's voice, go to step g),
    6) Ask the recipient to set recipient's fax machine to receive faxes.
    7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
    Dialling The Coded Speed Dial
    1) Prepare for faxing.
    2) Press the Coded Dial button.
    3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
    4) Press the Color button for color sending, or the Black button for black & white sending.
    Hope this helps. Please rate my response.
    Thanks
    Have a good day.
    Lexmark t640 error 920.46
    If you can E-Mail me at [email protected] I will send you the step by step directions on how to fix your problem.
    Have a great one.
    Thank you for using Fix Ya!
    How to Fax
    Dear sir,
    you can download the complete User manual, from this site,it will help you use step by step use of your All -in-one printer:
    http://www.generalmanual.com/down.php?link=aHR0cDovL2gxMDAzMi53d3cxLmhwLmNvbS9jdGcvTWFudWFsL2MwMTM2ODU3My5wZGY%3D
    Be Happy Always
    regards
    1helpful
    Cannot receive faxes
    Step one: Check the fax number
    Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
    If the issue is resolved, you do not need to continue troubleshooting.
    If the number is correct, continue to the next step.
    Step two: Dial the number manually
    Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
    If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
    On the product control panel, press the Setup button.
    Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
    Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
    Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
    Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
    Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
    Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
    Try to send the fax again.
    If the issue is resolved , you do not need to continue troubleshooting.
    If the issue is not resolved , continue to the next step.
    Step three: Run a fax diagnostic test
    Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
    Make sure that there is plain white paper in the input tray.
    On the product control panel, press 6 , and then press 6 again.
    This selects the Tools menu and then selects Run Fax Test .
    The fax diagnostic test page prints.
    Review the results of the test.
    If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
    If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
    If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
    If the solutions on the printout do not resolve the issue, continue to the next step.
    While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
    Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
    Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
    When the product is in the ready state, try to send and receive a fax again.
    Step five: Test the send/receive functions
    Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
    If the product is working correctly, the following events occur.
    When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
    When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
    After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
    Review the results of the fax.
    If the fax is transmitted successfully, continue to the next step.
    If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
    If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
    Step six: Use an analog telephone service
    HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
    To obtain digital services information or support, contact the telephone service provider or system administrator.
    Step seven: Check the phone cord and fax connections
    Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
    Figure 1: Telephone cord with two wires
    Figure 2: Telephone cord with four wires
    If the cord has four wires, replace it with a two-wire telephone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
    Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
    Figure 3: Fax only
    1 - Telephone jack
    2 - Telephone line
    3 - 1-Line
    4 - 2-Ext
    If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
    Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
    Figure 4: Fax and telephone
    1 - Telephone jack
    2 - Telephone line
    3 - 1-Line
    4 - 2-Ext
    5 - Telephone
    Figure 5: Fax and PC or modem
    1 - Telephone jack
    2 - Telephone line
    3 - 1-Line
    4 - 2-Ext
    5 - PC or modem
    If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
    Step eight: Remove any other devices from the telephone line
    If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
    NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
    Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
    Try to send a fax again.
    Step nine: Perform a partial reset of the product
    A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
    Disconnect the power cord from the back of the product.
    Wait 20 seconds, and then press and hold # and 3 on the product control panel.
    Connect the power cord to the back of the product, and then release the buttons when the product turns on.
    The product is reset to factory defaults.
    Try to send and receive faxes again. If the problem still exists, continue to the next step.
    Step ten: Service the product
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    1helpful
    Scanning
    You can do this through the microsoft word. When you scan your document, your program will ask you where you want your document to go,you can direct it to ms word. you can send your email from microsoft word .easy
    Note: it is important to install the software that came with the printer.It is this software you are going to work with to send your scan to ms-word,
    Good luck
    Error code 0502 lexmark 5150
    Send me an E-Mail at [email protected] and I will be able to send you the step by step directions to your issue.
    Have a great one.
    Need directions on setting up fax for Epson Stylus CX4800 All-In-One
    Hi , dial fax number send hear a sound from telephone ringing , sometimes voice answering machine then press enter.just follow instruction .
    Norman Weimar
    Norman Weimar
    k24674
