DISSAMBLING SAMSUNG R40 Hello there, SAMSUNG R40 I got the same problem. I don't know how to dissamble my SAMSUNG R40, and the cooler seems to be clogged with dust, so I'm afraid I'll fry my laptop. I've been able to get the keyboard off, and I've removed every single screw I could find, but no luck... I can bend the case apart slightly in some places, but other places are still held firmly together, particularly near the display hinges and near the audio connectors at the front. I suspect there are plastic tabs inside the case holding it together, but I can't see anything from the outside, and I'm obviously reluctant to use force... This would also be useful for the users of Samsung R60. Can anyone give me a hint as to how I can get the case open? Any tip will be highly welcome!. Thanks.
  • 518 Answers
If you are not sure what you are doing, it would be a lot better if you put it back together and called a pro to clean it for you, at least it will work when you get it back.
Posted on Jun 24, 2009
Samsung r40 reset to factory settings
hello there Start by pressing F4 when the BIOS "Samsung" screen is showing. This will allow you to restore the original operating system from the recovery partition, if is there. (Also try the other Fn keys - F6 and F8 may do something).
Otherwise you will need to beg, borrow or buy an XP Home installation CD and use that for a new installation. You can use the Samsung key on the bottom to activate it. You can get the R40 drivers from SamsungPC.
Feb 12, 2013 | Samsung NP-R40 NP-R45 NP-R65" (CL102791)
How dissambling gateway w340ui
watch this:
http://www.youtube.com/watch?v=CMo6_0mkEE8.
Mar 11, 2012 | Computers & Internet
Samsung plasma appears to overheat and displays bright blue areas on screen - mostly where picture should be white.
may be the fans are blocked or malfunction.
Don`t continue using if is overheat, you can broken others parts.
I recommend clean the TV, put the blower or aspirator near the vents air (slots for ventilation).
If you can dissamble the TV, remove the fan and check it or replace.
You can buy it at your service center
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Samsung HP-T4264 42 in. Plasma HDTV
Screen some time coming some time gon
Hello, please check your lcd cable can lose contract,
Disassemble the note book and re connected the cable. .
Follow the bellow link.
You can use an camera for recording how to disassemble,and fit it again.
Step no 7
can duble click For large
http://www.irisvista.com/tech/laptops/ToshibaM55/laptop_LCD_screen_removal.htm
it s not your model ,but help you.for dissambling.
http://tim.id.au/laptops/toshiba/satellite%20m50.pdf
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 21, 2011 | Toshiba Satellite M55-S135 Notebook
Lg 23ls7d wont turn on.No light goes on when its plugged in, nothing happens it's just dead. I checked the power source and its fine. I don't know what happened? Can you help
Five capacitors (green) on the power board may be the source of your problem. If they are high centered then you may need to repace them. Usually it will be only 2 or three but I would replace all that are swollen. The cost of the capacitors is very low. The expensive part is having a specialist do it. If you feel up to it, learn how to disassemble the back but photograph every step, even all the cable connections before dissambling. Tape & mark all your screws and connections. I took different colored indelible pens to mark the connections to make sure I got them connected correctly. My TV works well except that now I have to figure out why it comes on by itself. I need help with this problem.
Mar 12, 2010 | LG 42LB1DRA 42 in. LCD Television
My iphone won't turn on. It won't charge it just has a sliver of red when I plug it in with an electrical bolt displayed underneath. I've unplugged it and plugged it in again a bunch of times, but no...
maybe your batteries died, try letting it charge for a couple of hours and see what happens,, if it doesnt do the trick try dissambling the unit, and check the batteries if you cant take your iphone to the nearest apple store
Nov 10, 2009 | Cell Phones
VIDEO RECORDING NO SOUND WILL BE HEARD
1st check you video in the computer.
If you hear a sound, i think your problem in your internal speaker or in the motherboard.It' simple if the problem in the speaker.Just change it.But if the motherboard is trouble, i can't help you.Maybe one resistor is dead/not properly work.
If you don't hear sound. May be you have a mix problem.Change it.
I warning u, be carefull dissambling the camera. Before you do that, you must have sparepart. If you don't, you can bring it to service.
Apr 08, 2009 | Olympus FE-210 Digital Camera
Canon EOS Rebel G
it seems you have a dirty lens,sticky mechanisms prevent smooth movement of lens cause by excessive moisture,blurry foto cause by fungus on your lens,pls note dissambling ang cleaning your lens requires patience and rigourous training.
Jul 12, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Computers & Internet Logo
626 people viewed this question
David Payne
David Payne
