Question about Acer Aspire 3610 Notebook
The cover broke at the left hinge, lifting it from the base
The cover broke at the left hinge, and it lifted from the base of the laptop, when I closed the laptop, carefully, as usual. The right hinge had a minor crack. Since then I no longer close the cover. I bought my Acer on May 2006, over 1.5K. Can you help? I am retired and the only person using my laptop. I would like to avoid replacing it, I love the product.
I need a laptop by July 29, to travel. I am a writer. Many thanks.
Anita Junge Hammersley
1205 Priory Lane
Ottawa ON K1C 1Z8
  • 63 Answers
U could buy a new screen or mayby for a quick soluition u could super gule it but i got no other ideas
Posted on Jun 24, 2009
Tip
How to repair Hinges on a HP ZV6000
<p>If a loose screen hinge screws <br /> <p>1. Turn off your computer and remove all components of the computer that sending an electrical current to the system, including power cables, peripherals and battery. <br /> <p><br /> <p>2. Close the display and turn off the computer base to cope with the hinge side of the computer to you. <br /> <p><br /> <p>3. Extract the four screws on the bottom border. <br /> <p><br /> <p>4. Remove the rubber plugs on the back of the hinges of the screen and the two screws underneath them. <br /> <p><br /> <p>5. Turn off the computer and open the screen, so they sit flat against your work. <br /> <p><br /> <p>6. Press the area marked on the right side of the keyboard cover (the plastic strip on the top of the keyboard) to it from the computer. Lift your right a little push and cover the central part of the keyboard to release it. Lift up the middle and let the left up to the keyboard cover for free from the computer. <br /> <p><br /> <p>7. Unzip, the four screws on the top of the keyboard and the keyboard on the fold of the palm rest with the buttons down. Disconnect the keyboard cable and remove the keyboard. <br /> <p><br /> <p>8. Loosen the two screws that secure each display hinge to the computer. <br /> <p><br /> <p>9. Attach the keyboard and the keyboard. Make sure all screws that secure each part to fix. <br /> <p><br /> <p>10. Place the screws on the back of the hinges of the screen and replace the rubber stopper. <br /> <p><br /> <p>11. Insert the battery, cables and components that you removed in step 1 to complete the process. <br /> <p><br /> <p>Broken so replace hinges <br /> <p>1. Turn off the computer and get rid of its power transmission components. <br /> <p><br /> <p>2. Turn off your computer and remove the four screws on the hinge side of the base of the keyboard. <br /> <p><br /> <p>3. Remove the rubber plugs on the back of each screen hinge, and pull the two screws in the hinges. <br /> <p><br /> <p>4. Unplug the computer and open the screen. Follow the instructions to step 6 of chapter 1 to the keyboard cover. <br /> <p><br /> <p>5. Remove the keyboard by following step 7 of Section 1 <br /> <p><br /> <p>6. Disconnect the cable from the connector on the computer screen right in the middle of the screen panel. <br /> <p><br /> <p>7. Disconnect and remove the two antenna cables from the mini-PCI wireless card in the middle left of the keyboard and cables in the guide, take it to the computer. <br /> <p><br /> <p>8. Unzip the two screws on each hinge and lift the computer screen. <br /> <p><br /> <p>9. Remove the six rubber pads on the front panel display, and remove the screws under them. <br /> <p><br /> <p>10. Remove the display. <br /> <p><br /> <p>11. Unzip the two screws on each screen, internal hinges and remove the hinges of the screen. <br /> <p><br /> <p>12. Follow the procedure in reverse, with hinges to the new computer installation. Make sure you remove all the screws, so everything is nice and tight as the computer is assembled. <br />
on Jun 22, 2011 | Computers & Internet
Tip
How to remove the hinge cover on a Gateway PA6A, MX8711 1. You will need to is...
1. You will need to is unscrew the two screws that are on the back of ether side of the hinge cover.
2. Next take small screw drivers gentle pry up on the right hing cover. Note this piece is designed to flex a little.
3. Then lift up on the hinge cover slowly and it should release. Note you may need to pop the left side cover with a screw driver.
At this point you should have the hinge cover off
on Mar 24, 2010 | Computers & Internet
I replace the screen on my gateaway mt 6916 and cant install the video controler driver
Instructions
Prepare the laptop for disassembly. Shut down the laptop completely, then wait a few minutes before removing the battery and unplugging the AC adapter. Turn the laptop over and lay it down on a flat surface so that the battery area is facing away from you and the hard drive is located at the bottom left corner.
Remove the hard drive cover. Remove the two screws located on the left side of the hard drive cover, then lift the cover to remove it completely from the unit.
Remove the memory cover. Unscrew the eight screws holding the memory board in place; this cover is located above the Gateway product sticker.
Disconnect the Wi-Fi adaptor. Remove the Wi-Fi cover by unscrewing the single screw holding the Wi-Fi adapter in place; this is located directly above the hard drive. Remove the two cables connecting the wireless card to the adapter and snap the card out of the holder.
5
Remove the memory modules. Gateway computers typically have two memory modules located in the center of the motherboard; lift these out gently with your fingers and set them aside.
6
Release the heat sink. Unscrew the four screws around the heat sink assembly; this unit is located to the left of the ventilation fan and is surrounded by a copper base. Carefully lift the heat sink and the cooling fan off the unit and unplug the cable attaching it.
7
Remove the CD/DVD drive. Unscrew the small screw located to the left of the CD/DVD drive, then push the drive out to remove it from the laptop completely.
8
Remove all screws around the base of the laptop. You will now be left with a total of 18 screws located around the edge of the base of the laptop, and in between the stickers and hardware components in the center. Remove all of these carefully and set aside in a safe place.
9
Prepare the cover for removal. Turn the laptop up on its edge so that the back of the laptop is facing you; you will see two screws on the hinges of the computer. Unscrew these and set them aside.
10
Remove the hinge cover. Open the laptop so that the screen is laying flat; use the flathead screwdriver to pry open the hinge cover and pull it off gently with your fingers.
11
Remove the keyboard. Lift up the keyboard and reach behind it to release the cable. You will need to tug gently on the cable to unhook it from the motherboard.
12
Unhook the LCD screen from the notebook. Unplug the Wi-Fi antenna cables located on the right side of the motherboard directly under the screen, then unplug the video cable located directly under the hinge cover. Remove the pair of screws located to the left and right of the LCD screen and gently lift the LCD screen off the notebook's base unit.
13
Remove the system board. Turn the base unit over and unscrew the five screws securing the motherboard to the base. Two of these are located near the hinge cover, and two are located beneath and to the right of the hard drive unit. The fifth is located a few inches below the top right edge of the laptop.
14
Disconnect the motherboard. Lift the system board, then unhook the cable connecting it to the base unit.
Jan 10, 2013 | Gateway DX4200-09 PC Desktop
Acer aspire 5253 power button broken due to hinge
Have a repair shop or person look at this---it may be fixable now but if you keep using it the issue may get worse.
Nov 05, 2012 | Acer Aspire 5532 15.6" Laptop Original...
Need to replace broken key on keybord. plastic appartus on key underside broke
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Have a dcp8020. Went to copy document and it said to put the doc. cover down. looked down to me. went to lift it and put it down again [gently] when the cover just lifted up. seemed to rise up on the...
I think those plastic hinges are removable ..just lift the lid up in a 90 degrees angle with the printer face ..and try to insert them both in the same time ..it has a snap in kinda action ...and after that close it ..
Sep 01, 2010 | Brother Office Equipment & Supplies
4 beeps but won't come on
4 beeps of equal lenght suggest that system timer is not working, you need to change cmos battery on your laptop. If you are game, that is how you change CMOS battery on your laptop:
1. Switch off computer, remove power cord and battery, turn computer "proper" side up, open and press power button to discharge
2. Open display in full (180 degree), there is small indent on hinge cover, close to hinge on right and left side, slide in little flat (screwdriver will do) and lift right side up, slide cover towards left and remove it, do not lift on both sides simultaneously!
3. Remove two small screws on the top of keyboard, lift keyboard slightly up and towards you, be aware that keys and tabs on keyboard are fragile and difficult to replace! Lift keyboard connector and slide the cable out. it is not really necessary to remove keyboard, but it easy to replace without keyboard being in the way.
4. Find coin battery, disconnect cable from socket by pulling it gently towards the battery. Remove cable from guides and battery from it's seat
5. Replace battery with exact same type, put it back into it's seat, guide wire through and connect it back to the board.
6. Re-connect keyboard cable, place front keyboard tabs into palm rest and screw back two back holding screws
7. slide in left side of hinge cover into place, press from left to right till it click in place.
8. Re-install battery and power cord, switch on computer, re-programe BIOS ito previous state.
This should solve your CMOS batery problem. Of course you can send your laptop to the technician but that will be no fun at all... ;-)
Aug 07, 2010 | Dell Inspiron B130 Notebook
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
Acer Aspire 3610 Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
