Question about GE Refrigerators
I have a regrigirator unit that doesn't have a freezer and it has condensate pooling in the bottom and dripping out of the front.
I removed the back panel from the inside of the refrigerator were the coils are and cleaned the drain that goes to the tray in the bottom. The condensate from the coils was just overflowing into the bottom of the refrigerator.
Posted on Jun 25, 2009
Ice forming on bottom of freezer compartment under freezer baskets...then finding water on the floor. Frequency is once every few days...Fridge is a Kichenaid KFIS27CXMS5
The unit defrosts itself and the water runs down a tube into the drip pan under the base. There is a coil (condenser) that gets warm and helps to evaporate the water in the pan. These things get very dusty and gross. Remove the front kick panel and clean the drip pan, check the drain hose for obstruction all the way to the evaporator coil in the freezer and make sure the unit is level.
Mar 12, 2018 | Refrigerators
Why would condensation be running down the sides,or water dripping from bottom?
should be a small plastic tray funnelling from under the fins in back to a small hole n hose out the back of unit check owners manual if possible,..
Jul 08, 2014 | Delfield Freezer 6125XL-S
Water condenses on outside bottom of freezer and drips on floor
I would not remove the bottom and replace the insulation. Where is the unit located in your home?
Nov 02, 2012 | Refrigerators
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
Water pooling at the bottom of refridgerator
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 02, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water is pooling in the bottom of the freezer
Nov 16, 2009 | Maytag MBB2256G Bottom Freezer...
Sub Zero 611F "vacuum condenser" warning persists, unit not 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
Pooling Water
Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
Dec 23, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
