Question about Yamaha Full-Size Keyboard
I purchased the Casio Wk-1800 in 2000. Moved
I purchased the Casio Wk-1800 in 2000. Moved around a bit, haven't played it for a while,...just set it up again and the input jacks aren't working,....any ideas?
No but can't afford to join any plan
Posted on Jun 25, 2009
Casio wk-7600: I just purchased it and trying to set it up. I connected a dynamic mic. in "mic. in" slot as the user manual described. The mic. didn't amplify my voice. Do I have to configure the use
Use only DINAMIC microphon (computer microphons are not dinamic- they are condenser-electret) with MONO jack.
1. Turn knob (beside "mic.in") "mic.volume" (T-7) full clockwise.
2. Press "MIXER" (C-7).
3. Press "<" (R-17) while is shown "MIXER PART>:EXT(M/I)
4. Set (check) Part [ ON]
Volume: [80...127]
N.Tresh [0]
If after microphone disconection there is a noise from speakers - set
PART [off] or N.Tresh [20] (or higher))
Jan 12, 2014 | Casio Music
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
How do you replace the adaptor jack on a Casio WK-1200 keyboard ? is it easy ?
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Feb 02, 2011 | Casio Music
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
http://support.casio.com/pdf/008/WK200_500_e.pdf
Oct 22, 2009 | Music
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 | Casio Music
Want to connect to my Vista PC but...
Have you tried signing on to your computer as the administrator? I looked at the support pages at Casio and saw how confusing they are. Look at page: http://support.casio.com/information.php?rgn=5&cid=008&pid=114 and page: http://support.casio.com/information.php?rgn=5&cid=009&pid=115. Pay attention to the red lettering. The computer might be considered as the midi out device and the keyboard as the midi in device or the other way around, I'm not sure. Pretend its a telephone conversation with one person talking and the other person replying. I don't know if this helps but you can also try tech support at Sweetwater Sound (800)222-4700.
May 24, 2009 | Casio 76 Key Smartmedia Keyboard
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Yamaha Full-Size Keyboard Logo
448 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
