Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
TV won't come on
My TV power button comes on but there is abosolutely nothing that appears on the screen or any sound at all. The TV is on but the screen looks just like it does when the TV is off. There is no soud either.
  • 3 more comments
  • steven_fr986 Jun 25, 2009
    The unit has been unplugged and then later replugged and still no change. I have removed the back panel and observed that 3 green bulbs and one red one lit. Thers is another that is not lit at all.
    Comment posted on Jun 25, 2009
    The unit has been unplugged and then later replugged and still no change. I have removed the back panel and observed that 3 green bulbs and one red one was lit. There is another that is not lit at all.
  • steven_fr986 Jun 26, 2009
    Power is coming into the system.
    Is there a way to do that (or reset the TV) without the remote? My remote does not seem to be working
    My remote control does not seem to work, nor does the up/downchannel on the tv work. Would it be helpful if I provided which lights on the circuit board are working? Also, is there another way to reset the TV?
    President:
  • 1,865 Answers
It sounds like a component has burnt out, take it to a repair shop
Posted on Jun 27, 2009
    Sergeant:
    Champion:
  • 233 Answers
Try Changing the input. It' on VIDEO and it's looking for a video input device, like a DVD player or VCR.
Posted on Jun 26, 2009
    President:
  • 1,734 Answers
As far as I can see your power supply is damaged. This needs to be fixed at a local service location.
To locate an authorized HITACHI service facility in the continental U.S.A. and Canada,
DIAL TOLL FREE
800 HITACHI
7 days a week, 24 hours a day
(1-800-448-2244)
Posted on Jun 25, 2009
    Brigadier General:
  • 3,917 Answers
HI, check the wall outlet to make sure that it is live.if you are using a surge protector, i would pull the unit from the protector and, try a wall outlet. sometimes the surge protector will short out and, it will seem that the TV is the issue. if the protector is fine and, the wall sockets are ok, this will confirm a more serious issue that concerns the power sector inside the unit.
You will need to replace the power supply board or, fly back assembly in this case.
the only thing to reset is have the tv unplugged and let it rest for about 10 minutes, allowing it to cool down,if power still wont do, your unit needs servicing, have the power checked for output voltages that goes to the horizontal deflection circuits, hope this help, thanks for using fixya!
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
The unit comes on using the power button as well as a remote and displays "Polariod" on scrfeen and then nothing else, no sound no picture?/
More than likely your power supply needs two electrolytic capacitors, 10MFD @ 450 WVDC. If you find the capacitors on the power module to the top of the metal enclosure inside the tv, they will probably appear to have swollen tops.
Mar 01, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Toshiba TV won't turn on
Toshiba? Suspect that if it uses a Lamp for brightness (a model number would help) it may have failed----customer replaceable and if remove look to see it is not shattered inside--2 year, 2000 hour life is normal.
Oct 29, 2012 | Sony Televison & Video
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
AOC A15X221 have picture no sound
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
Insignia tv will not powerup
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
Nick
Sep 09, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Emerson EWF2705, when pressing power it sounds like it is coming on but nothing happens
Hello DEBM,
The problem with your television appears to be in the high voltage power supply or the low voltage power supply. The set tries to come on but the shutdown circuitry turns the TV off. The shutdown circuit is a protective measure put into place to prevent overcurrent and overvoltage conditions by shutting down the TV when these conditions exist. If you do not have a background in electronics, might I suggest that you have a TV technician to come to your location and work on the TV.
I hope this helps
Thabk you,
Shuttle83
Oct 15, 2007 | Emerson EWF2704 TV
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
