Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Changing the lamp
Where is the lamp located on the tv and how do I change the lamp once I find it? I've been looking for it but can't seem to find it. Thanks.
It is behind the front speaker grill
Posted on Dec 20, 2007
TV will not power on
Inspect the lamp again. When you replace it, make sure you DO NOT TOUCH the glass. Make sure all doors and covers are securely in place before you turn it on.
As a rule, expensive lamps have a very short life.
May 01, 2017 | Panasonic PT-43LC14 Television
My rca whp141 doesn't seem to work with my Sony 32 Bravia Kdl32L4000. Can't get the light to light up on the base Please
Press the menu button from the remote, look for "Settings". You should have a "Sound" category. Once you've located that, press Enter to go into the submenu. You want to look for "Audio Out" option and change it from the default "Variable" to "Fixed". Then you should have sound in your headphone. You can just either mute or lower the volume of your TV. Hope this help.
Jun 30, 2010 | RCA WHP141 Consumer Headphones
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Sony kds-60a2020 lamp problem
I would change the whole LAMP ASSEMBLY because if you touch the lamp while changing it out of the housing the oils on your hands will cause premature failure.Most of the time the lamp assembly's come with replacement instructions but yours is not too bad it is located on the left hand side if looking from behind set.
Sep 10, 2009 | Sony KDS-60A2020 60" HDTV
Panasonic tv model pt-50LC14 will not turn on
First, turn off the tv. Once the fan has stopped, unplug the tv. Remove the front cover from it latches (takes up most of the area below the screen). On the left is the lamp door. One screw holds the door. Remove lamp door. Looks like one screw holds the lamp assembly. Loosen screw and remove lamp. Lamp may be hot if the set was running before you began the lamp replacement.
If you have a new lamp assembly, reverse the process. If a new lamp without assembly, change lamps. CAREFUL. No fingerprints on the new lamp. The oil in the fingerprints will shorten the life of the new lamp.
Reset lamp hours in the menu when done.
Sep 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sony rear projection TV
If your tv uses a lamp then change the lamp
Apr 27, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
TV lamp, sound.... don't come on...
The balast has a plug going directly to the lamp. There is also a thermal fuse coming off of the balast that lies above the lamp housing. Check for continuity. If open, replace.
Oct 03, 2006 | Panasonic PT-45LC12 45" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
