Brother AX325 Typewriter
When we press the keys the correct letter is not coming up how do i clear it ? For example when pressing the letter B it comes up with 1/2
  • Anonymous Dec 09, 2008
    the problem of our typewriter AX-325 is when we pree the letter B it come up with letter T.
    Problem Solver:
  • 19 Answers
Look to see if you are Keyboard 1 or Keyboard 2. There might be something interfering with the daisy wheel,just check the fitting of the correction tape and have a look at the daisy wheel itself. See that none of the petals are distorted.
Posted on Nov 05, 2007
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
Feb 27, 2013 | Brother SX-4000 Typewriter
What buttons do I push to erase on my sx4000 brother typewriter
Providing you have the proper supplies and they are correctly installed you just type a wrong letter, press he correction (KEY WITH AN ARROW AND AN "X" ON IT).
DickyO
Sep 29, 2011 | Brother SX-4000 Typewriter
When you press the key the typewriter moves but no
change Cassette daisy wheel.one with the letter
Jul 02, 2009 | Brother ML-100 Typewriter
The keys don't type the correct letter
Loosen the screws that hold the silver guide, one on each side of the carriage. Adjust to touch platen with 2 sheets of paper installed. When you reset next time it will reset to the right letters.
Jul 01, 2009 | Brother GX-6750 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
Brother ML-500 Typewriter Typing the wrong characters
The printwheel is not in correctly. the printwheel has a bent spoke or the printwheel homing sensor needs cleaning. Lawrence
Feb 14, 2008 | Brother ML-500 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Correction function not working
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
226 people viewed this question
k24674
jasbo
jasbo
