Question about HP Compaq Presario V2000 Notebook
System problem My Laptop, suddently became slow, it happens when I download music video, it just stop downloading. Can someone tell me what to do Thanks Jean
  • 1,006 Answers
Re: System problem
Virus infected!
Hdd Problem
Ram problem
Posted on Nov 05, 2007
0 characters
3 Points
I have a mx6436 laptop and when i listen to music it cuts out and i have all the codec packs instlalled help !!
Maybe you need more memory on your laptop. How much memory do you have? Click Start/Control Panel or Start/Settings Control Panel and look for System or System and Performance. When you open System it will tell you how much memory you have on the General Tab.
Try using another player to listen to your music such as the VLC Player.
Try using VLC as your player. Go to and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
Jun 09, 2012 | Gateway MX6436 Notebook
Restore laptop to factory settings
Try doing a system restore first, take computer back to a earlier time before this happened.
Mar 18, 2012 | Fujitsu Siemens PC Laptops
Hi, My laptop taking so much time to switch on and it became very slow. Please tell me the soluiton for it.
Sometimes slow booting of computers and Laptops are caused by viruses and spywares. Also, a High temperatured Processor makes a computer slow.
Here are some solutions you might want to try.
  1. If you have a installed antivirus in your computer, i suggest you update your Antivirus and then Start scanning your computer for possible viruses and spywares.
  2. If viruses and Spywares are not the problem, maybe your Processor is feeling to much heat. I suggest you use Laptop Coolers like this one. heifentrixx_11.jpg
  3. This will help you cool down you Processor and Laptop.
Hope my solution will help. Thanks for using Fixya!
Jul 08, 2011 | Toshiba Satellite Pro L300 Notebook
Video slow on laptop, music stuter's I have a
Sounds like you have too many programs running at once, try to shut down programs that you are not using, this will open up more memory because video and music takes a lot of your 3mg memory. If it still does not work you will have to upgrade to higher memory. You must have 3GB memory, 3MB memory sound too small.
Oct 23, 2010 | Dell Inspiron 1720 PC Notebook
I have dialup. i can't download or playback music
Check with your local ISP (Internet Subscription Provider) if they have a wireless modem/router so you can connect to the internet wirelessly.
They will be the one to configure your internet settings.
Happy surfing!!! ^_^
Jun 08, 2010 | Dell Inspiron 1526 Laptop
Audio problem on acer aspire one zg5 A150
Try installing the audio drivers again, this might resolve your problem unless you have a physical problem in your speaker.
Visit the following link and download the sound drivers again on your system. This would resolve your issue
Apr 21, 2010 | Acer Aspire One Netbook 8.9" Notebook
Help for laptop L305-s5907
sounds like internal ram fried .due to a virus thats affecting Ram and cpu
Jun 28, 2009 | Toshiba Satellite L305-S5907 Laptop
I have toshiba L305-s5907. i have switch from vista to xp. than i have downloaded drivers from toshiba website but after that my laptop became very very slow. When i was using vista at that time it's RAM...
The reason that XP is only recognizing 3GB of memory is because the operating system is 32bit (X86), what you need for the OS to recognize 4GB is a 64bit (X64) system, does your laptop support 64bit? if it does then get a 64bit install disk, install that and your system will be able to use the full capacity of the 4GB memory installed.
Low memory slow running video/audio programs host process stop working
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
May 17, 2009 | Acer Aspire 5520-5908 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
