Question about GE Advantium SCA1000H Convection / Microwave Oven
Light is out
I need to know how to replace this light...
how do you get to it?
  • GE Master
  • 9,098 Answers
If the owner's manual does not address it, then it is probably not meant to be replaced by a non-professional.
If it is not accessable by a panel hidden by the vent grille, then the oven will have to come down out of the wall so you can remove the outer wrapper.
Posted on Nov 05, 2007
How do i change the light in the oven. The lights are out, I just need to know how to replace them.
If the lamps are internal, the cabinet will have to be removed to replace them.
Nov 19, 2017 | In Microwave Ovens
We have a Panasonic microwave 1200 we've replaced the bulb and switch but still no light every thing else works
I would need to know which light, the cooktop / work lights or the inside lights. And I would need to know which switch you replaced.
I would need the FULL model number & "FCC ID" number from the tag in cooking cavity or around door frame or control frame or on back.
For more free DIY and other help & advice, feel free to contact me via my site. Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 13, 2017 | Panasonic Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
How do you replace the internal oven light?
You need to first unplug the microwave. Then if you look at the back/bottom, there are screws/bolts holding on the outer metal cover on the microwave. Remove all screws that you find on the outside and the outer panel will come off and give you access to the light bulb that you can then replace. Let me know if you need any more help on this.
Nov 03, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a Sharp R1200 Microwave oven and the internal Light bulb burnt out, and the digital LCD does not display all charaters, Is this something a homeowner can repair ? FYI I am very technical so as long...
Hello William,
I see you got back to me and I dowloaded the manual, but not sure how to repair this microwave, the inside light is burned out
and the display numbers do not light up correctly, as if some of the pixels are burn out. So I need to know what I need to replace ( LCD panel)? where is the bulb located and how do you remove and replace it, It should be easy once I know what and where to go
Mar 22, 2010 | Sharp R-1200 Microwave Oven
Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Jan 23, 2009 | Danby DMW1153 Microwave Oven
GE Advantium SCA1000H Convection / Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
