Question about Pioneer DEH-2300 CD Player
Setting the clock
Can you help me set the clock thanks a mill..
  • Anonymous Dec 28, 2007
    Can,t get the clock to set on my DEH-2300. I have push in on the clock button but can not get it to change.
  • me244hurt Feb 20, 2008
    how do you set the clock?
Mine was able to do it when its in the off position or if a cd is playing just not during radio play, which is just weird.
Posted on Mar 11, 2009
Try this, I know it worked on my Player and it is the same model:
1) Switch the sources to 'Off'.
2) Press the "Audio" button for 2 seconds. This is the button to the upper right of the 4 arrows.
3) Adjust the time using the left or right buttons to select the hour or minute and the up and down buttons to increase or decrease the time.
4) To set the time, press the button below the "Audio" Button. WARNING: Pressing the "Audio" button again will cancel your changes.
Posted on Sep 28, 2008
    Problem Solver:
  • 15 Answers
This must be done while a cd is playing
Posted on Mar 29, 2008
Set rev limit light
Hi Anonymous, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. DOWNLOAD 2000 Aprilia Rsv Mille
Mar 01, 2014 | 2000 Aprilia RSV Mille
Are there automatic grain mills? I've only been seeing hand mills on Amazon.
Most of the mills that you will see on sites like amazon are hand mills but I found the Nutrimill to be a really amazing machine mill, its quiet and quick and has many different settings. EQUIP Nutrimill Grain Mill Amazon com Kitchen Dining
Jan 23, 2014 | Kitchen Appliances - Others
Engine does not idle well
Hi, Popes2k and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
Jan 30, 2012 | 2003 Aprilia RSV Mille R
Setting the time on rsvr 2001 clocks
to set the hour, Press D twice, the hour will flash, then press the LAP button, (this is the little lever you when flashing your lights) until desired hour is reach. Press D to confirm.
to set minutes, press D three times, and again use the LAP button until you reach the correct minutes.
Press D again to confirm.
Apr 05, 2009 | 2001 Aprilia RSV Mille
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
Pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Feb 18, 2009 | Pioneer DEH-P500UB Car CD/ MP3 Player
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Hinari mx310 microwave setting the clock i lost instructions
Here is the latest contact info for Hinari:
Hinari by Alba
Pulse Home Products Limited
Customer Care Department
Vine Mill
Middleton Road
Oldham OL2 5LN
Customer Support 0161 652 1211
Fax number 0161 652 0538
Oct 23, 2008 | Microwave Ovens
Pioneer DEH-2300 CD Player Logo
146 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
