Question about RCA F32649 32" TV
Rca tv i have a rca tv f32649 model number and had a zenith remote that worked it. we went to replace the batteries in the remote and then it would not work again and we do not know how to reprogram the remote. after this we went and bought a rca universal remote and it works the tv well but it will not access the av channel or the input channel or the channel for the jacks on the front of the tv so i cannot use my dvd player any suggestions?
  • 1,694 Answers
Re: rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Posted on Dec 03, 2007
0 characters
3 Points
Can't get the Wii system to work
Push the who/input button on the remote. Keep pushing it until you get the "video" option.
Dec 29, 2009 | RCA F32649 32" TV
RCA Guideplus Gemstar TV
one of the button switch is still working or stock up, you need to replace all the switch to besure.
Oct 31, 2008 | RCA F32649 32" TV
RCA F32649 32" guide plus TV
you need to check the fuse ,maybe it's busted.
Sep 04, 2008 | RCA F32649 32" TV
Rca F32649 32"
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons will leak when they get old causing them to activate on their own. your channel up or down button is stuck on. take off the back cover and you will see a small clip in circuit board behind the front panel. take out the board and remove the channel up or down switch and your set should work fine again. the remote will still work fine for changing the channels.
Aug 14, 2008 | RCA F32649 32" TV
RCA ctc203ca6 model f32649
the front panel assembly is rca part # 237420
I assume your chassis is a CTC203
Un plug the fpa and see if problem still acts up
you may not be able to find one
then try replacing the sticking buttons on it
Jul 26, 2008 | RCA F31317 31" TV
Code for my tv
My RCA 32" code for t.v. is 0047...
Jan 25, 2008 | RCA F32649 32" TV
RCA F32649 Television
Replace flyback transformer and horiz output transistor.
PART # ' S 244247 and 237470 .......T.
Let me know..........Provide service # off back to confirm.....
Nov 01, 2007 | RCA F32649 32" TV
RCA F32649
Sounds like you have a shorted horizontal out put transistor and bad flyback transformer. This is a common problem in the newer RCA's. I've had serveral of them do this. The noise that you hear is the power supply telling you that it's overloaded. Stargazer
Feb 17, 2007 | RCA F32649 32" TV
Channels keep changing
ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Jul 07, 2006 | Toshiba 36A40 36" TV
RCA F32649 32" TV Logo
164 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
