Question about Refrigerators
GE ice maker
I have a GE Model TPX24BRBB WW refrigerator. The ice maker would notstop making ice unless the bale arm was lifted clear up to the offposition. I was advised that it could not be fixed and to replace it.The original IM had a GE part #WR30X328 I was sent the new one (part#WR30X10061). Everything seems to fit except the the fill cup that camewith the IM is for a side fill or can be moved for rear fill. Whenpositioned for rear fill, the fill tube would have to come out of theback wall between the mounting screws. My fill tube comes out to theright of the RH mounting screw. What am I missing? Thanks, edgilb
  • 473 Answers
I carry this ice maker on my truck and they are supposed to come with a universal cup so it could be mounted either way. See if you can pull off the cup of the old one and switch it to the new one. If not have them send you another ice maker because that one is not right.
Posted on Nov 05, 2007
How do I shut down the water flow to the ice maker
There are three ways.
1. Shut water off to the fridge via plumbing valve.
2. Lift arm on ice maker or use on/off switch depending on ice maker model.
3. Unplug ice maker wiring harness. It won't be able to call for water.
It depends on why you want the water off. A make and model of the fridge would help so I can give you a more specific answer.
Apr 05, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Turn off ice maker on Whirlpool refriferator freezer model ED2FHASB03
On the right side of the ice maker there is a long metal lever called a "bale". Carefully and slowly lift that lever to the 90 degree position. You should feel a catch and the bale will remain in that position. That shuts off the ice maker operation.
Oct 02, 2014 | Refrigerators
How do I turn the icemaker off; it is making too much ice, GE model GSH25JFXN WW?
This is a quick guess. Look at the top of the ice bin. Many refrigerators stop the ice maker with a wire bale that rides up on the ice. Raise the bale and it should latch in place above the ice and shut off the icemaker.
Aug 14, 2014 | Refrigerators
Ice Maker Arm of Kitchen Aid Superba 36
There is trick to putting the ice bale arm back on unless the water cup where the water comes into freezer has the round opening broken that holds the bale arm Click Here=> 628356 Water Fill Cup
Also the video clip from Parts Select will show you the way to do this way of reinstalling the bale arm. If movie does load below then click HERE Telling you how in words would not be as simple as the instructions given in the movie. Thumps up to Parts Select on that tutorial! I will be here if you have questions and please rate if helpful Thank You Sea Breeze
Oct 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Apr 29, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
326 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
