I had this problem on a weekend. I rang for advice and a tough old emergency sister told me to apply cotton balls soaked in OP brandy. Did it ever work.
I was dead drunk when I got to the dentist on Monday, but when I explained they laughed. The dental assistant said anaesthetic and disinfectant probably weren't needed.
You should rinse the tooth off very gently, make sure it is
clean. Do not remove any tissue that is attached to it.Be careful not to drain your tooth in the
sink. If you can, gently place the tooth back into the socket. If this is not
possible, place the tooth in a small container or cup of milk. In both
scenarios you should rush to your dentist.
Brush with best toothpaste, Rinse your mouth, Visit your dentist regularly, Drink some tap water, Avoid frequent snacking and sipping, Eat tooth-healthy foods, Consider fluoride treatments. If i will talk about toothpaste, Sensodyne Fresh Mint toothpaste relieves sensitive teeth by building a protective barrier that blocks the sensitivity caused by hot, cold, sweet and other contact triggers and it keeps it from coming back.
