You don't rewire it
If necessary to replace some of the wire
for any reason, you repair the oe harness
You buy the same gauge wire,any color,solder
& heat shrink the part your cutting out.
If only the ends are a problem & you have enough wire
to reach the pump, you have to get the wire terminals
& replace them & hopefully use the oe connectors
If the connectors are problem, then you source your parts
from a salvage yard & do your solder thing
If your asking about buying a fuel pump & it looks or is wired
different,it is the wrong one, take it back
You just plug in the new pump,there is NO Rewiring or the pump
is not for your application ,or it came with no instructions
