It would probably be best to contact Potterton or Baxi Potterton
at the email address: [email protected]
www.potterton.co.uk
Potterton Myson, send all enquiries to Baxi Potterton
I only found one PDF file online and it was a general book that showed how to wire most of the wire systems and controllers.
http://atibook.com/dl/en/Others/Tutrial/9780750664363_domestic_central_heating_wiring_systems_and_controls.pdf
SOURCE: how can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
No idea how I managed to get my problem entered into the Riding Mowers etc but it really is a Potterton central heating controller, honest
