What does the scan tool show.??
? still P0106, and did you reset it?
did you try to start car with MAP disconnected, some do start in limphome mode. rich a a pig but starts.
did you have key off when you fiddled the MAP connector,
or better pull the battery neg, lug first?
lost power to the mAP, check the power pin.
lost ground to sensor.
lost vacuum to the sensor (clogged paths)
Bad MAP sensor Water/dirt intrusion affecting MAP sensor connector Intermittent open in the reference, ground, or signal wire for the MAP sensor Intermittent short in the reference, ground, or signal wire for the MAP sensor Ground problem due to corrosion causing intermittent signal problem A break in the flexible air intake duct between the MAF and the intake manifold Bad PCM
(do not assume the PCM is bad until you've exhausted all other possibilities)
try to recheck the spark plug distribution cable arrangement otherwise check your spark plug may be one of it is short or the gap is not proper.
