Question about LG VX8300 Cellular Phone
Broken LCD repair
The LCD inside my LG VX8300 is broken. Can you supply instructions for me to replace it myself? Is the lens over the LCD a separate part?
  • dobie57 Nov 16, 2007
    Is there an update to this problem of the cracked LCD on inside of LG VX8300
Check
www.247laptoplcd.com they have insturctions with Laptop LCD how to fix it also.
Posted on Jul 25, 2008
You all are every mean my phone was bronken and you all did not help.
Posted on Jan 23, 2008
  • 133 Answers
Boss this is not an easy job. To replace the LCD u will have to separate the top portion from the other. I would suggest take it to a reliable technician and he will do the job for u.
There is a flex cable that is connected to the main board through the hinges of the phone and even if u manage to separate the two care should be taken while fixing it again as the new flex (that comes with the LCD display) may get jammed if wrongly done. Only an expert will help u here
Posted on Nov 05, 2007
My lens fell down and I think is not broken but the front part is separated, can I repair it myself or should I sent it to customer service?
Get a quote first for the repair as this lens is the least expensive Canon lens and it could be that the combined cost of postage and repair will exceed to cost of a brand new replacement.
Feb 11, 2011 | Canon EF 50mm f/1.8 II Lens
My LCD has broken . my mobile is LGKU099R
You need to replace the LCD screen.
If you have repaired small electronic by yourself you can try DIYing, otherwise take the phone to a repair shop.
Instructions: LG Viewty KU990 disassembly
Part: LG KU990 Viewty LCD screen
Do not forget to leave feedback.
Many thanks.
May 29, 2009 | LG KU990 Viewty
Lens broken does anyone know where i can purchase one
Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
LG KF700 LCD Display Screen Replacement
Apr 16, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
1998 ford taurus 12-volt socket broken, how to repair
well... speaking, that the socket does not work, then replace it, you can find the parts over at napa, and it will come with simple instructions, its not that hard.
Mar 29, 2009 | 1998 Ford Taurus
My LG VX8300 phone has a cracked camera lens cover. I would like to replace it myself if LG can provide the parts. Can you help with instructions? Thanks!
I repaired mine by using a knife to pick out the old one. Then I opened the back by removing the 4 screws and prying it apart. I cut a piece of clear plastic the size of the lens from a flash memory box, removed the black ring around the hole on the inside and pressed the new lens in, replacing it. I used a little glue to hold it in and put the black washer on top of it. Then I closed up the phone. It works great. With the new lens inside, it won't get broken again.
Bill
Sep 28, 2008 | Cell Phones
Canun digital camera powershot A630 lcd screen blank
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
Jul 11, 2008 | Canon PowerShot A630 Digital Camera
LG VX8300 front and main screen are black.
2 possible causes - the LCD and/or LCD electronics PCB board is faulty OR the flexible ribbon cable may be kinked or broken. If you are knowledgeable in electronics repair, you can make this fix yourself.
Jan 15, 2008 | LG VX8300 Cellular Phone
LG VX8300 broken camera lens
hi is it the outer case of the phone that has the crack or is it actually the lense of camera as often it is the cover over the lense that gets broken as the lense on the camera itself is tiny.
If this is the case and it is just the case that needs replacing you can either take it to phone shop and they will replace for a small fee the only problem with doing it yourself is the screws need to be undone in a certain order and the same putting them back getting this wrong can warp the board and destroy the phone.
The only sites i have found that shows you how to strip phones down only covers nokias.
You could try using ask.com and typing in what you are looking for as sometimes you will come across a site containing the info you need.
If the problem is with the camera itself this will require unsoldering and a new camera soldering back onto the board but you problem is probably just the case.
They are difficult to take off as once you have undone the screws their are clips holding the case onto the board itself and if you damage these you wont be able to get the phone back together again.
Ill have a look now for you and see if their are any sites with instruction on for you and will post back if i find any but try using ask to search for you you might be lucky let me know how you get on ok
Dec 29, 2007 | LG VX8300 Cellular Phone
Broken camera lens - 5 min after I got it!`
I must have dropped it just right. Is there a way to replace that tiny bubble lens?
Dec 10, 2007 | LG VX8300 Cellular Phone
R&R Front Lens on LG VX8300
Simple. The fastest way is to find a thin edged blade and gently pry up to old lens. Ensure you do not lose any of the adhesive tape that holds the lens on as you will need it to put the new one on. You'll need compressed air to keep dirt and debris from getting between the lens and the LCD.
Nov 12, 2007 | LG VX8300 Cellular Phone
LG VX8300 Cellular Phone Logo
111 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
