At first specific speakers began dropping out, then on a movie music or sound effects were fine but dialogue inaudible, now it is just dropping out completely. Only output that works is Headphones. Input is via optical cable from Foxtel IQ
SOURCE: Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
SOURCE: pioneer sx-255r only plays mono sound out of left speaker
The PCB is probably cracked. It can be repaired, but I am going to assume any shop would charge you at least 100$ or more. With the age of the unit, you are missing many of todays modern features (which may or may not be of concern to you). If you are interested in saving the most money, then consult your local repair shop, as you will probably not be able to replace it for the $ to have it repaired. But if you are willing to spend a bit more, then you can have a new, modern receiver with no repair history.
SOURCE: very low output from the center speaker, cannot
also try turning up the level of your centre speaker in your Reciever setting, as well as make sure that the center speker is available thru your setup.
Turk
SOURCE: I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps don
hope this helps
don
hope this helps
don
