SOURCE: need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
SOURCE: Printing only upper part of page - big graphic PDF
1: check in the printer properties( page setup ) is it latter then make it A4
2: clean the roller
3: also when u printting check with uper try not from try 2
if its printing proper then try is touching roller
SOURCE: canon ir 2020 ng 853 error.
http://www.usa.canon.com/opd/controller?act=OPDDisclaimerAct&fcategoryid=2281&modelid=12301&id=57901&file=/cpr/software/imagerunner/PCL5e-c_v8.55_Win2k-Vista_INF.exe
Try this for Vista 32 bit operating system printer driver.
SOURCE: iR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
SOURCE: Canon iR3225 document feeder feeds only one sheet
Did you change separation assy and pick up assy for DADF?
