Home | Hoover | SteamVac Carpet/Upholstery Deep Cleaner Vac... | I am using a hoover ult...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Problem for Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
I am using a hoover ultra steam cleaner but the
By jo_mac1953 on Jun 24, 2009
I am using a hoover ultra steam cleaner but the red ball keeps coming to the top . I assume this indicates it is full and ready to empty however it is still empty . The red ball will not stay down in order to operate properly
Comments:
Jun 24, 2009
- thank you
Best Solution
posted on Jun 24, 2009
Helpful)
Milleniumboy
Rank: Wiz
Rating: 78%, 22 votes
Thankyou,
The redball indicates that it is full, that is due to the high resistence its suction system is inducing, because it is empty and it still stays up, I would try to turn the power settings a little lower, or it is experiencing high pressure from operation. Also, if you could adjust the bristles, or losen around the air vents. This should do the trick.
Thankyou, :)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hoover SteamVac
Questions and Unsolved Problems for Hoover SteamVac
Do you recommend Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum?
Answer
Answer
I have a Hoover Steam Vac Spin Scrub F899-910. It is not sucking up the excess water from my carpet.... (More)
Answer
I have a Hoover Steam Vac Deluxe, Model #F5865-900,Serial # 109700048476. It no longer squirts the... (More)
Answer
I have a hoover vacsteamer and it will not release water/cleaner to shampoo carpet
Answer
can not figure out to switch from tool cleaning back to floor cleaning mode?
Answer
has a split in the vac hose where it hooks to the machine. Also won't spray water from floor... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover SteamVac...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
