Brother MFC-5840CN All-In-One InkJet Printer Logo
A
Anonymous Posted on May 23, 2014
MFC5460CN PRINT UABLE ERROR 51 - Brother MFC-5840CN All-In-One InkJet Printer
Brother mfc240c #51 cant print error code.What to do
https://www.easyink.co.nz/support/brother-mfc-665cw-unable-print-51-error-solved/
How to clear error 51
Check type of printer it may need cartridge or special paper
roll to print.
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
2answers
My brother printer has an error unable to clean 50
If you facing Brother Printer In Error State Windows 10 check this Answer.
Brother Printer In Error State Windows 10 is a failure normally displayed when the printer is jammed, low in paper or ink, the cover is open, or the printer is not connected properly, etc.
It is informed that customers usually face the Brother printer in the error state. There can be various circumstances liable for this problem. The obvious factors include outdated printer drivers, incorrect printer settings, certain technical difficulties within the print spooler service.
There are some method that fixes Brother Printer In Error State Windows 10 Easily check here:-
Method 1: Reset the Printer Settings.
Method 2: Ensure that the Brother Printer is Online.
Method 3: Set the Print Spooler Service as Automatic.
Method 4: Install Windows Pending Updates.
Method 5: Update the Printer Driver.
Full Blog- Brother Printer In Error State Windows 10
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Error 51
One or more ink cartridges may be empty. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See page 143 of the manual for instructions on replacing the print cartridge. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Norman Weimar
Norman Weimar
k24674
