Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Transfer from Harddrive to the the free agent 250 GB
Hi , what is the fastest way to transfer data from the pc to the free agen
  • 1,006 Answers
Re: Transfer from Harddrive to the the free agent 250 GB
Posted on Nov 05, 2007
0 characters
3 Points
How do I reconnect the WD harddrive to the Bell PVR with out losing what I have already transfer
It is very simple, just re-connect the device and restart the process for remaining data and simultaneously check if you have lost any data or not. If you have lost your data then you have to show your machine to an expert for Recovering Data from Hard Drive.visit us
Oct 24, 2014 | Western Digital WD Passport 250GB Portable...
Seagate FreeAgent|Go getting really hot while transferring files from PC to the external hard disk. Do I need to replace it?
No. External harddrive enclosures that don't have fans are generally going to get quite hot during extended use.
Mar 27, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have an iomega 250 gig external hd. went to plug it in one day and my pc said it couldn't read any of the files. i can still see thumbnails and view photos but can't transfer any data at all. please help...
i have an iomega 320 gig external hd. went to plug it in one day and my pc said it couldn\'t read any of the files. i can still see thumbnails and view photos but can\'t transfer any data at all. please help as i stupidly put all my files on this drive. about 10 years worth of work.
Dec 02, 2010 | Iomega 33089 250 GB Hard Drive
Seagate freeagent 500gb not getting powered
is the power frequency different out in india, it's not just the voltages you have to watch!
If you can remove the hard drives and use a usb interface to connect them then software like filescavanger will recover files providing the hard spins up ok.
Jan 11, 2010 | Seagate Free Agent Go Small 12 GB USB...
Seagate Free Agent Drive cannot be modified? Worked before...
Sounds like it's one of three things then
Disk trouble from unplugging the usb while the unit is still "running" and not yet finalized. Running CHKDSK /? /F in the run box where ? = extrenal drives lettrer. Then restart the computer(done from windows PC with drive attached)
Shell trouble I have already advised a dozen or so people this week that if CHKDSK doesn't work, replace the shell with a new one and see if the hard drive works in the new shell.
Failed harddrive, of course this is always an option. If neither of the above suggestions works then it's possible the hdd has failed and you may need to send it to a pro if you have any files on it that need retreiving.
Hope this helps FixYa, if you need additional help just reply to this by adding a comment.
May 22, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi i got a buffalo tb external hardrive and the pc wont recognise it now after i transfered alot of data when the pc froze and i had to turn pc off mid transfer . please can you help
It is probable that since the transfer did not complete, the data on the external drive will be corrupt.
Uninstall the external drive then reinstall and format the ext drive.
You should then be able to begin the data transfer process again.
It just sounds like bad luck that your pc froze mid transfer.
When you try again, do not use the pc for any other uses until the transfer has completed.
Regards and let me know if this works for you.
Feb 24, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
How to transfer files from one harddrive to another harddrive?
install the new harddrive where you want to transfer your files and set tis jumper to slave and set the jumper of the other harddrive from where your files are located to master. when you open your pc you will two drives C: and D: open c: and locate your files and you can use the 'copy' or the 'move' command and select the drive where you want to put your files
Oct 15, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
My harddrive will not save files larger then 4 GB
What is the filesystem format on your external hard drive? there are limits on certain file systems, like maximum size of a single file in fat32 is 4gb. let me know the filesystem on your external hard drive and i will try to consult a few friends for you. regards
Apr 18, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
145 people viewed this question
Top Seagate Hard Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Seagate Hard Drive Expert? Answer questions, earn points and help others
