Question about Brother MFC-3240C All-In-One InkJet Printer
Unable to print
The prompter says: maintenance and trouble shooting as in the maintenance chapter.
However I never received a booklet. Could you send me that instruction please.
hank you so very much
  • samlou Nov 15, 2007
    have a brother mfc 425cn and it says unable to print refer user guide trouble shooting & maintenance chapter we have shifted and cant find guide. we have changed ink cartridges a call centre said to turn off for half hour, didnt help.
  • Brother Master
  • 1,113 Answers
Menu * 2 8 6 4 super quick then 82 will show error
If you get error 41 that means the print head stuffed not worth repairing
too many other codes to list.
Posted on Dec 29, 2007
  • 1,006 Answers
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken. (Thank you David Price,
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Posted on Nov 05, 2007
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
Unable to print See trouble shooting and routine maintenance chapter in User's Guide
might be a coagulation in the ink in the cartridge in the fax machine. check it if so dip it in mild hot water for some times and replace it wiping the water and it would work.
May 08, 2011 | Office Equipment & Supplies
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
 email me if I help you. .
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Error message
try to re-instal the driver or check the cable
Mar 16, 2009 | Office Equipment & Supplies
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
967 people viewed this question
James Cagle
James Cagle
Jim Keysor
