My oven digital display has gone blank, but still beeps if you press buttons, and the light does come on. How do I get the frame off so that can remove the control board, and how do I change the fuses if that is the problem?
SOURCE: Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
SOURCE: OVEN BLACK-OUT!
Read this troubleshooting page, it may provide you with a solution to the problem.
http://www.repairclinic.com/0088_13_1.asp
SOURCE: control panel for oven functions
The control panel may have a power issue. Replacing the board fixed my problem. It looks like 4 resistors and a ZD1 diode heat up and fail. The U1 chip could also be a problem. If you replace the controller it will cost around $225. Be careful of the key pad ribbon cable. They break easily. Another $186. Good luck.
SOURCE: The display is blank, yet the light comes on. The
i'm assuming everything works but you cant see the clock?
if this is the case then you need a new clock board.
very common on these wall ovens
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
