It turned itself off and red light started blinking 7 times then goes off for 3 secs then same again,and tv wont reboot
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
SOURCE: philips 42pf7320a/37 dead
I do agree with the tech but if the green led don't come on and the 7-blink error code is still there. check the connector from the logic board that will be the board under the small signal baord. The small signal board have the AV input on it. Check the connector from the logic board to the power supply there should be one connectore btween those 2 boards. On the power supply side second pin from the left it will say Vs_On if the set has 0 volts the proble is the SSB or the logic board. how to determain that is to Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU (see figure below).
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (this will supply a 100% White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
