Question about Sony PlayStation 2 (PS2) Console
Disk reading error
I brought a new disk and my ps2 is not reading it
  • 709 Answers
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Posted on Nov 04, 2007
5 Suggested Answers
SOURCE: my Ps2 isnt reading disks!
we used this tape thing and it worked the first time,,,,,hooray,,,,a happy child......
Posted on Aug 20, 2007
BUDDY08
  • 128 Answers
SOURCE: dispaly cannot read disk
DONT FORGET TO RATE SOLUTION
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Posted on Dec 29, 2008
localwonder
  • 6784 Answers
SOURCE: My PS2 wont read any disk.
HI, the optics assembly has failed. the actual optical lens assembly will need to be replace in this case. you can try to clean the lens with a cleaning disk.. this may wake the laser. if the cleaning doesn't produce results, replacing the optical lens assembly will be the next move.
Posted on Jul 21, 2009
mybradley7
  • 242 Answers
SOURCE: my ps2 wont load any new games i have
try a WET cleaning disk
Posted on Jul 14, 2010
Disc read error
its either a dirty lens inside the drive or a dirty disk. start with trying a lens cleaner.
Jun 12, 2008 | Sony PlayStation 2 (PS2) Console
My playstation 2 makes a weird clicky sound when I try to play some of my dvds or games and sometimes it comes up with disk error or unable to read disk and its a brand new disk
Your PS2 lens is displaced from its original position that is what scratching your Discs and makes weird noises too.There can possibly be another reason for them ,your PS2's reading lens is dirty and it is covered by a layer of dust that scratches your Discs and makes sounds too.
You should first clean the lens of your PS2 watch this video to know how to clean your PS2's lens:
Disk read errors are mainly due to dirty or worn out lens,so clean your PS2's lens to get rid of this problem and as for that sound that will get fixed by cleaning lens if still it makes that sound then you will have to take your PS2 to repairer to set the lens height.
Thank you!
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slimline SCPH-75001 disk read errors
Believe me or not, i have the exact same PS2 model no PS2. Most models had Lens problems of 75001, si thats the reason, I chnaged my PS2's lens for 25$ and now all's fine, so change yours too mate!
Mar 21, 2009 | Video Game Consoles & Games
Gta error reading disk
Sounds like an issue with the laser.
Mar 02, 2009 | Sony PlayStation 2 (PS2) Console
Slim ps2 disk read error
I don't want to put you down or nothing but, buying the slim ps2 wasn't a great idea. If you bought the original ps2 it would've been better. The thing about the thin ps2 is the hd is small, the laser tends to become weaker faster. Go get the ps2 checked out someplace.
Jun 26, 2008 | Sony PlayStation 2 (PS2) Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
Format disc
i think the disk is defected and you should exchange that disk with a new one......
Jan 16, 2008 | Sony PlayStation 2 (PS2) Console
My new ps2 game wont work
if your ps2 is old, it may not take certain disks e.g. purple backed disks, dvds and a disc read error problem will appear in the browser
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Format Disk??? PLEASE HELP!
i got the new disc fixer to playstation2 to fix the ps2 games to take out the scratch and it did'nt help
Jan 03, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
