Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Buzzing sound I've found that with my vocal mic I have no problems, when I use any of my guitars i have a buzzing noise persisting in the background! Any thoughts or tips would be usefull! thanks!
  • 49 Answers
Poor grounding.. loose grounding or replace the wire with with the best quality grounding......
Posted on Jan 21, 2008
No mic coming though on vocalist live 4
Sounds like the mic you are using requires "Phantom Power." This means, you will likely have to purchase an external unit for this power (+48V) power to the unit. I use a Behringer Ultra-Voice Pro for mine. Works great!! You can find these on Ebay at a steal!
Jan 13, 2013 | Digi-Tech Digitech Vocalist Live 4...
I am going insane trying to figure out why my vocals are recording so inconsistently - volume all over the place. It isn't obvious until I take the wave file to my engineer who's recording my CD. ...
hmm, it could be something simple such as a faulty cable from mic to pc, it could be a faulty input if you are using a mixer, could be a faulty mic, it could even be a piece of software running in the background that is conflicting with sonar and causing this problem. This should be an easy problem for your "engineer" to sort out. as seeing it makes it 100 times easier to fault find. Thats part of being an engineer!
Sep 03, 2011 | Edirol UA-25 External Sound System
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
NT3 or NT1A?
Either mic will work for piano, vocal and guitar.
Jan 02, 2009 | Rode NT3 Professional Microphone
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
SE2200A "wind" noises during recording
Its very descriptive and is quite a common problem with less expensive condenser mics. It's due to dirt or contamination on the capsule insulator or front end circuitry of the electronics. SE should be able to fix it for not much money.
Aug 26, 2008 | SE Electronics SE2200A Professional...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
( or customerservice
Dec 18, 2006 | Magic Sing Along Consumer Microphone
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
361 people viewed this question
Top Lexicon Computers & Internet Experts
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
