Question about GE 32GT740 32" TV
No power My tv is actually a thomson(ge) 25gt516 and when i changed the fuse it immediately burned out again. What is the problem?
  • 99 Answers
You have a short that is causing your fuse to blow. If you dont have any electronic expertise in trouble shooting I dont sug you proceed . And allow a pro to look at it.
sorry for not being to help.
good luck---------------tomtaso
Posted on Nov 27, 2007
No power on zenith z36x31d
The fuse may have failed. However, since you mention smelling something burning, you'll need to check if other parts (for example: a resistor or diode) also was damaged. That burning smell suggests that you had a short in the circuit and high voltage got past the fuse. If you insist on fixing the TV, you will need to identify any short and fix that before attempting to use it again.
I hope this helps.
(I've dealt with several resistor fires over the years. Sometimes the resistor or Zener diode is actually the fuse for the circuit. That simplifies the solution.)
Jul 11, 2014 | Zenith Z36X31D TV
I have a thomson 29dh78k and a blown fuse . i changed the fuse and blows again . hehp!
There is a direct short circuit in the main power regulator circuit. Never put any more fuse, till the fault has been rectified. It will cause more fault to develop. Contact any experienced service technician.
Dec 30, 2012 | Thomson Televison & Video
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
I have a LCD TV THOMSON 32lb040s5, the problem is that the TV start and turn off again and again when I start it
you probably have a fault on the stand by power board.
this normally requires soldering and maybe some componet changes. This is not a job for the unskilled. best carried out by a service engineer(shock hazard)
there is a service kit for this available from tvs-services.com 012453925
Jan 18, 2010 | Thomson 32LB130S5 32 in. LCD TV
My menu wont pop up
the micro processor IC might be malfunction, and the connection to the OSD need to check.
Jun 28, 2009 | GE 25GT516 TV
Is the is TV Digital or Analog?
if your grandmother has cable or satelite tv she already has a digital signal however if she justs gets her locals she will need a converter box. the goverment is giving free coupons for this or she can go to walmart and purchase a directv converter box for about $50 she will not have directv but the box will convert her signal.. the tv has nothing to do with the signal. she will not need a new tv.
Dec 12, 2008 | GE 25GT516 TV
Change message on ge model 29875ge1-b.....lost manual
hold down the greetings button and speak when it beeps
Nov 09, 2007 | Thomson 29875GE1 Answering Machine
GE 21GT660 does not power on
ok you can see the fuse at the power section! near at the cord coming to outlet! or maybe you heve defective fusibul resistor!
Oct 21, 2007 | GE 31GT660 TV
GE commercial skp television
open & go to http://www.fixya.com/support/p237154-ge_25gt240_25_tv/manual-11916/page-11 go through the user guide & try your problem will be solved.
Oct 05, 2007 | GE 25GT516 TV
GE 25GT516TX1
The GE (actually RCA) 25GT516 uses the CTC185 series chassis. The dashes you show look like the old display of a clock that has not been set. I have never heard of this chassis producing those dashes continually on the screen, so the first thing I would do is eliminate any cable box, satellite receiver, DVD or VCR. If you have cable, run it directly to the set and see is the dashes are there. If you are sure that the dashes are being generated within the TV and you have properly set the clock and turned off the OSD, then it soulds like an EPROM problem and the set should be serviced by a qualified tech familiar with the CTC185 chassis.
Jul 24, 2007 | GE 25GT516 TV
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
