Question about Sony MHC-GX450 CD Shelf System
How do I connect the subwoofer to MHC-GX450 sony stereo system?
SOURCE:
SOURCE: sony mhc gx450 stereo mp3 hookup
alguien sabe espanol
Posted on Sep 19, 2008
landsend
  • 1066 Answers
SOURCE: How do I connect ipod to sony MHC GX450
you can buy a Belkin docking station for about $20  or you can buy a headphone to RCA plug connection wire.  I like the docking station as it has a remote and charges the ipod as well.  Shop ebay
Posted on Mar 27, 2009
romsky79
  • 822 Answers
yes you can connect using rca phone jack to rca jack it depend on what cable you use from your ipod. connect from your ipod audio output to auxillary of sony mhc-gx450.
Posted on May 31, 2009
ETRONIC
  • 62 Answers
SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Posted on Feb 16, 2010
tbreeze47
  • 3083 Answers
SOURCE: why do my sony mhc-gx450 cd shelf system power
This usually indicates faulty wiring, or miswiring. Disconnect the wires, one set and turn the unit off and on to see if that elimates your problem. If it does, the wiring or component is at fault. If you disconnect everything and have the same problem, it's an internal fault with the unit and will have to be troubleshot. Get and estimate first, to evaluate whether or not it's economical to keep, or replace with a new one. Good luck, hope this helps.
Posted on Mar 25, 2010
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
My subwoofer for my sony mini component system mhc-gx450 will not work any sugestions???
Is the LED on the front of the subwoofer unit glowing?
If not then check that (a) the plugs are correctly inserted in the two sockets on the back of the the mhc-gx450, and (b) check that the subwoofer is activated on the mhc-gx450 unit.
Oct 15, 2011 | Sony MHC-GX450 CD Shelf System
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
My stereo won't even read the CD-player cleaner. Where is the laser lens, so I can clean it?
You need to unscrew the Sony MHC-GX450 CD Shelf System where the player is located and pull the whole DVD/Cd assembly.I suggest you have it done by professional technician since the laser lens is very sensitive.If its not reading the CD cleaner it only means that the laser is worn out and needs to be replaced.
Jan 25, 2011 | Sony MHC-GX450 CD Shelf System
How do I connect ipod to sony MHC GX450? can i hook my ipod to my sony mhc-gx450
May 31, 2009 | Sony MHC-GX450 CD Shelf System
Mar 27, 2009 | Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 CD Shelf System Logo
340 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
