Question about Sanyo DS13204 TV
Remote stopped working
My DS13204 remote stopped working. I switched the batteries and still noting. I can't switch the input mode.
How can I tell if the problem is from the remote transmitter or TV receiver?
How do I know if a universal remote is compatible with my TV?
Thank you
  • 1 more comment
  • Barbara Nov 04, 2007
    Thank you for your answer.
    Do I need a code? If so, where do I find it?
  • Barbara Nov 27, 2007
    Thank you everyone for your help. This story has a happy ending.
    I finally had a chance to get out and get a universal remote. The store promised I could return it, if I can't get it working.
    The instructions listed a choice of codes for Sanyo. The TV worked with the first code I tried. Hurrah!
    The instructions were surprisingly and refreshingly clear and easy to follow. Thank you again.
  • Anonymous Mar 07, 2008
    my remote si not working and i've switched batterries and still nothing.
    Problem Solver:
  • 14 Answers
I wouldn't recommend purchasing a universal remote and I would actually try to find the original remote control by searching on google with your model number or you can try a site like http://www.remotecontrolscenter.com and search through their catalog for the original remote that came in the box with your Sanyo TV. I hope this helps!
Posted on Nov 06, 2007
  • 4,889 Answers
Here are the codes...the best part is that the x10 universal remotes are also easy to find on the internet..
http://kbase.x10.com/wiki/Universal_Remote_Code_List
Posted on Nov 05, 2007
  • eagle338
    eagle338 Nov 25, 2007
    The codes are in the link i gave you..the remote is what you have to look for..
  • 537 Answers
A universal remote will work with almost any TV. I woud just buy one from Walmart. They should be under 10 bucks. If it doesn't work return it for a refund.
Mike
If your TV is less than 10 or 12 years old, it is quite a good bet it will work with a universal remote.
Posted on Nov 04, 2007
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
How to switch to av mode on philipse vardana sl TV
Varadan has no menu button on it front panel to select the inputs. You must have its original remote control to select it input.
Feb 12, 2013 | Philips 20PT643R 20" TV
How do i get it to video mode if i do not have a remote
Hello
Without a remote control, there is no way to select its input. You just buy one universal remote control, which suits your TV. OK.
Dec 05, 2010 | Sanyo DS13204 TV
The remote just magically stopped working, even after new battery
Have you tried pressing the 'input' button again this time to switch from video to tv? This happens in quite a few cases where 1 remote is used for many products. Please try and let me know.
Aug 21, 2009 | Televison & Video
Program sanyo tv remote
hold the mode you want to program while you enter the code, then let go, and depending on the remote, it will blink
Apr 08, 2009 | Sanyo DS13204 TV
Video mode
do you meen by video mode that it is in an external mode via a scart lead. if so does it operate ok if the external inputs to the tv are removed ie only leave the aerial lead plugged in
Oct 30, 2008 | Sanyo DS13204 TV
How do i switch to my av mode without a remote
try going to channel 00, or look for the "aux" or "input" button on the tv. if anything you can get a universal remote control.
Sep 15, 2008 | Sanyo DS13204 TV
Can't switch from aux to video.
The universal remote will not work because there has to be an input button on it.
Aug 24, 2008 | Sanyo DS13204 TV
Switch t.v. input to play games
Your set is probably old enough to have a code set on most "universal" remotes.
I don't know in which country you reside but remotes for under $10 US are available from nearly any major store such as Walmart or Target and I suspect at equivalent stores elsewhere.
Apr 29, 2008 | Sanyo DS13204 TV
Programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Apr 03, 2008 | Toshiba 42H81 42" Rear Projection...
Sanyo DS13204 TV Logo
240 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
