Question about Dell Inspiron 6000 Notebook
Startup problems laptop will only startup after several attempts, I can barely make out the screen, I just keep turning it off till the screen lights up, this can take several attempts, seems to be getting worse. Laptop functions completely normally once going, tho if screen saver is on too long, the screen will not come back on and the start up ritual must begin all over  again
    Brigadier General:
  • 6,966 Answers
Based on your post/description "barely make out the screen" you have a backlight problem which can either be the CCFLamp or the inverter that powers it. The problem may be component failure, heat related or cold solder, loose connection.
Since this would involve opening the screen display panel, electronic circuitry diagnosis and possibly component replacement, your best bet might be to seek the services of a qualified repair person. To give you an idea of the possible cost, pls refer to this site.
Should you venture into giving it a go for yourself, this site might be able to give you an idea how it is done. This link is a possible source of replacement components.
Hope this be of some help/idea. Post back how things turn up or should you need additional information.
Good luck and kind regards.
Posted on Nov 05, 2007
I turn laptop on an screen is black... fan comes on power button lights up but no display
Do you get any beeps when the laptop starts up? There is a POST (Power on Self Test) routine that attempts to diagnose startup problems and send beep codes (pattern of short/long beeps) before the main programs start up. If you get any beep codes, you can search for your computer model with 'POST codes' added if you have access to another computer. That might tell you what was wrong. Also try disconnecting from AC and removing the main battery for 15-30 minutes and then put both back on and see if you can get any different response from the laptop. Watch for any other activity such as the hard disk light or WiFi LED lighting also. If you don't get any response other than no startup, a tech would have to diagnose the problem from the motherboard.
Jul 24, 2014 | Computers & Internet
My hp 550 keeps freezing at the start up screen and it takes several attempts to get it to start up but when it does it works fine. it also starts ok in safe mode
Scandisk. Check HDD for SMART problems. chkdsk. Remove old unused programs. Check MSCONFIG for startup items. Use Ccleaner to clean up your computer. Use Malwarebytes Antimalware for malware removal. Defrag your HDD. You can use Auslogics Disk Defrag Screen Saver. Post results please
Nov 03, 2012 | HP Computers & Internet
My Sony VAIO Laptop screen is black. It worked fine, no issues2 days ago. Went to turn it on last night and it is black.. When light hits at a certain angle, I can see the desktop, I can hear the startup...
A faint and barely visible image on the screen indicates that the backlight(s) that illuminates the display isn't powering on. A device called an inverter board takes DC power from the laptop motherboard and converts it to AC power to power the screen backlight.
Before attempting anything below, be sure and remove the laptop battery and unplug the laptop
You need to take the screen apart and check to make sure that no cables are loose that are connected to the inverter board. If everything is secure, the next thing I would do is try to test the inverter board by hooking up an LCD from another laptop to the inverter and turning the laptop on to see if it lights up. If the other screen does light up, then the inverter board is likely good and your backlight needs to be replaced. Backlight replacement, unfortunately, can be very tricky for even an experienced technician, and many will opt to just replace the entire screen.
If you can't test the inverter board, then it might be worth it to order one and see if installing it fixes the problem.
Youtube is a great place to check for instructional videos on laptop repair, such as this one:
Sep 21, 2011 | Sony Computers & Internet
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
1996 Olds Achieva: Security light flashes upon startup
Several GM products, including the Chevrolet Impala and Malibu, the Oldsmobile Alero, the Pontiac Grand Prix, and Saturn Ion, have issues with the Security light coming on. This is many times an indication of a failing Body Control Module (BCM). Initially, the Security light will come on then go off, progressing to a constant on light, before the car will refuse to start. Other symptoms may include erratic action of electronics, a clicking sound coming from the glove box, and the air conditioning failing to blow cold air. I recommend a shop that specializes in the electronic systems of vehicles to diagnosis and make the necessary repairs. They should keep the car until they replicate the symptoms described. A new BCM from GM should cost about $230; plan on another $200 for them to diagnose the problem, replace the unit, and program the new unit. The dealers quote between $700 and $1,100 for the same repair. My experience and the experiences I have read on the internet, indicate the new BCM should last only about a year.
Jul 11, 2009 | 1996 Oldsmobile Achieva
Black screen I repair these all the time i hate to bare bad new but it a bad mother board.This is so common with sony laptops i have a stack of them with the same troubles. i just got a pcg k45 than seam to work good till you get to the starting windows screen and just shuts down.
Sony knows it has problems but they just keep selling them anyway. because it dont happen till the warranty runs out.A new mother cost about $425 for this model. Wish i could tell you something better
Feb 18, 2009 | Sony VAIO K45 Notebook
Stuck on the restart your computer screen.
You may have installed something in the startup items folder that your mac isn't liking.
When you turn the iBook on, press the shift key as soon as you hear the startup tone. hold it down until you see the gray apple screen. This will get you into safe mode, hopefully then you'll be able to fix whatever you did from there. If you are still at a loss, get in touch.
Dec 11, 2008 | Apple iBook G4 Mac Notebook
I want to reset my acer aspire T660 to factory setting like when it was first new
When you get the 'acer' screen at startup Hold down ALT and keep pressing F10. You need to be quick, it took several attempts for me. This takes it back to factory settings.
Dec 05, 2008 | Acer Computers & Internet
Screen broken
Did you attempt a hard shut down, meaning you hold the power button down till it turns off. To me it sounds like you damaged the LCD internally, I would suggest turning it off, charging it overnight, and then attempting to turn it on. It could be several problems I know mine did that when I water damaged it but I riced it and its fine now.
Nov 10, 2007 | Sony Ericsson S710a
Dell Inspiron 6000 Notebook Logo
154 people viewed this question
Alun Cox
