20 Other Users Have The Same Problem - Continued
Comment by donzichi, posted on Jul 12, 2008
ma touch screen just doesnt respond. though it releases atimes with so much difficulty. cant enjoy my dell axim anymore.
Comment by PamTL, posted on Jul 05, 2008
Screen does not respond - at first just couldn't write or edit but could get the abc/#s screen to come up and work from there. Now screen doesn't respond at all. Have tried reset couple of times without success.
Comment by Guest, posted on May 08, 2008
Touch screen not responding
Comment by jevansez, posted on May 05, 2008
Tried soft reboot several times with no luck. Finally tried a hard reboot and now have the screen asking to touch for alignment. Since the screen doesn't respond to touch commands, I am stuck.
Comment by Guest, posted on Apr 16, 2008
My LG Viewty tocuh screen stops responding when i step out of air conditioned office or home, in the open enviornment such as Mumbai where you have high humidity it literaly stops working !!
Comment by petta123, posted on Apr 09, 2008
my touchscreen was not responding, when i did a hard reset, i could not go past the 'tap the screen to set up windows-based device' written on the screen. pls help!
Comment by leicester100, posted on Apr 02, 2008
I have the same problem, but my i-mate pda is only 4 days old. It was working fine, but now the screen does not respond. I tried the full reset, but now I am stuck on the initial set up screen. Can anyone please provide the solution to this problem. Thanks
Comment by petta123, posted on Mar 10, 2008
My touch screen works for a couple minutes, then stops responding. I open the phone and it will work for a couple minutes, then it will stop responding. hard reset and soft reset do not resolve the issue. my phone is MDA vario II
Comment by nursinggost, posted on Feb 29, 2008
Have exactly the same problem with a
i-mate JASJAR Smartphone.
Searching for a software solution because changing the touch screen would cost too much and would be quite delicate (i dismanteled the pda and the touch screen and his connectors seem glued to the lcd, so it meens unglued the defected one).
Comment by spachy, posted on Feb 26, 2008
touch screen not responding
Comment by chappi, posted on Feb 19, 2008
I tried soft reset, hard reset and replacing the battery - my screen does not respond. Its only been 2 weeks since i bought the phone
Comment by azua123, posted on Feb 08, 2008
Comment by Guest, posted on Jan 05, 2008
soft resets, hard resets, removed memory cards, removed and replaced battery.
Comment by Nataly, posted on Dec 23, 2007
Have exactly the same problem with a hx2750.
Comment by Ariekikker, posted on Nov 08, 2007
Touchscreen of Acer n300 sometimes works for a few minutes, then it stops functioning although arrow keys are working. Resetting does noet help. Only after one or more days the screen functiosn again for several minutes.
