Question about Jenn-Air JJW8330D Electric Single Oven
Trouble baking Every time I use this new oven to bake cookies, they ALWAYS come out burned on the bottom. My cakes fall, and meats are alos blackened on the bottom , even if I use the uppermost rack position. What is going on? Is the oven not calibrated correctly?
  • Anonymous Nov 11, 2007
    self clean oven, will not release the lock.
    how do i release the lock??
  • Anonymous Nov 12, 2007
    Our new oven heats erratically. When a thermometer is placed in the middle rack it shows the oven 50 degrees or so below temp when the preheat light goes out and it takes up to 15 minutes to reach the set temperature. It then continues to climb up to 50 degrees over the set temperature and then falls 25 or 50 degrees below again. The control board and probe have been replaced but no change. The repair man said the thermometer is inaccurate (not true, it was checked in another oven), then said that all ovens take much longer to preheat than the controls indicate. We don't trust it to cook the turkey on Thanksgiving or the pies. The food sometimes comed out burnt and sometimes half raw.
  • 248 Answers
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Posted on Nov 04, 2007
Why does my new stove, bought Feb. 2014, have a problem cooking my meats or cookies?
Read your user manual about settings and rack placement.
Also check to see if you upper oven coil is working.
Ask your appliance maker or appliance repair shop.
Did you get a warranty for your oven?
Nov 30, 2015 | Ovens
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My baking element burned into. can my oven work with just the broil element or does it need both.
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
Dec 03, 2009 | Frigidaire GLEB30T8A Electric Double Oven
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy.
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn-Air JJW8330D Electric Single Oven Logo
200 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
