Question about GE Washing Machines
GE Washing machine not cycling
I have a GE Super Capacity 6 cycle heavy duty washing machine. The machine will start by filling up like it is supposed to with water. Then it just stops. I move the dial to the wash cycle and i can hear the cycle wanting to start and can hear the electrical contacts trying to hit. When i move it to spin and rinse they both work fine. Can u help please.
  • 1122 Answers
SOURCE: rinse cycle do not disengaged
does it drain?did you check the lid switch?
Posted on May 18, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
  • 1531 Answers
SOURCE: Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Posted on Sep 16, 2009
  • 3361 Answers
SOURCE: My GE Washer , which is a 9 cycle, 3 spd
You need to check the lid switch for continuity. A bad lid switch will prevent this machine from agitating or spinning.
Posted on Oct 05, 2009
  • 1543 Answers
SOURCE: GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Posted on Jan 21, 2010
  • 5911 Answers
SOURCE: water leaking during rinse cycle
If your TOP LOADING Whirlpool washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jul 05, 2010
0 characters
1 Points
I have a whirlpool ultim as text care heavy duty super capacity plus washing machine. Will only go through one cycle..will stop and hum. What could be wrong?
if it stops at the beginning of the wash cycle , it could be a failed start/run capacitor for the motor
if it hums at the start of a rinse cycle it could be a problem water control solenoid
Humming in a machine is a frequency vibration caused when something that is supposed to move is not allowed to and the resultant frequency sets up a vibration in the unit
if under warranty , get in a technician for a warranty fix ---if not get in a technician to check it out and get a quote for repairs
Mar 21, 2016 | Whirlpool Washing Machines
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Sep 16, 2009 | Washing Machines
Rinse cycle do not disengaged
May 17, 2009 | Kenmore Washing Machines
Washing Machines Logo
198 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
