Question about Sharp R-1870 Convection/Microwave Oven
Fans do not work properly
1- Fans are supposed to come on automatically per OM when Hi temp is monitored but not this one
2- Fans do not have any suction. They are mounted properly per mounting instructions (Non-vented)
3- Fans initially had Hi/Low speeds but no longer do
  • Sharp Master
  • 8,795 Answers
Re: Fans do not work properly
If the hood fan is not working at all, it would be due to a bad connection or other problem on the control panel (circuit board) or an open thermal or winding in the hood fan motor.
If you or a friend want to troublesoot this, I can give you some tips.
We have critical safety and disassembly information at our site, linked here on Fixya:
Posted on Nov 05, 2007
0 characters
3 Points
Is hertz the same as amps?
No, hertz (Hz) is the name for "cycles per second". Normal AC power (in the USA) is 60 hertz or 60 cycles per second. 1 kiloherz (KHz) = 1000 cycles per second. 1 megahertz (MHz) = 1,000,000 cycles per second. Amps is the measurement of current flowing through a device or circuit. a 100 watt light bulb pulls about 0.9 amps. A toaster or microwave oven pulls about 15 amps.
Sep 11, 2014 | Microwave Ovens
Panasonic microwave nnsn787s stopped working.
this seems to be a recurring thing with panasonic , im in the suspision of cooling fan not moving correct volume of air accross the magnetron and it overheats and shuts off on thermal hi temp safety
fans going to need to looked at by professional serviceman to determine this
Sep 10, 2014 | Microwave Ovens
My microwave intermittently blows the downstairs sockets
If it is tripping the breaker when you just close the door, I think it might be one of the door switches that the latch activates. There are usually 3 switches behind the latch holes in the microwave. One is a safety monitor switch that is suppose to blow the internal fuse if the microwave is started and the door is not closed properly. It should blow the micro fuse before the house breaker unless you have a weak house breaker. It will do the same thing if start is pressed and it senses a problem with the door. You say the problem is intermittent so I assume you do get it to work at times so I'm guessing most of the microwave is OK. I'm pretty sure you have a door switch problem--- either out of adjustment ---or 1 of them going bad.
Apr 03, 2014 | Neff Microwave Ovens
Everflow Model R126010BU fan failure
the coil for fan, can be reheating for the years and fluctiuation of voltage in line. Will be a GOOD idea to replace with the properly parts from factory or similar.Remember see the tech spec. like 115vca or 220vac OR 60HZS, watts.God bless you5e456c2a-fffd-4c17-b0d3-97799433e6cf.gif
Apr 02, 2013 | Microwave Ovens
We have a Kenmore builin icrowave with exhaust hood over the range. The exhaust fan appears to recirculate the air into the kitchen and not sending it out. This causes the cooking smell to remain inside...
some fans have a charcoal filter that needs replacing others are supposed to be vented out side by the roof or out the wall to see if the vent is going outside you will have to unmount the unit tak it down and check and see if it is conected to a duct in the celing or through the wall hope this helps
Mar 09, 2011 | Kenmore Microwave Ovens
Everything works on my microwave but it want heat anything. Lights, Vents, and Fans all work properly. There are no weird noises or anything, whats the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 09, 2010 | Whirlpool WMH1162XVS Microwave Oven
Screen goes black
It's a power save function. You can adjust it. If it's a pc go to "contol panel". There will be help there.
Mar 27, 2010 | Danby DMW119 Microwave Oven
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
Maytag mmv5000bdw Touch panel works intermittently The panel will not respond to the touch. Work around include: 1. closing the microwave door hard and trying again. 2. unplugging the microwave and trying...
If nothing works, it sounds like you didn't get the cable inserted properly. It should fit into a connector which carries signals to the microwave's control components. These connectors usually pullup, you insert the cable, and push the connector back down.
Oct 14, 2009 | Maytag MMV5000 Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
101 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
