Home | Mitsubishi | VS-60707 60 in. Rear Projection Television | After tv on 10 min...
Mitsubishi VS-60707 60 in. Rear Projection Television
Problem for Mitsubishi VS-60707 60 in. Rear Projection Television
After tv on 10 minutes, black horizontal lines appear
By Lorrainesfav on Jun 24, 2009
conversion OK, black lines start with 1 line then more appear after on a while.
Clarification Request
Posted by JMEastman on Jun 24, 2009
are the lines running horizontally on the top and bottom or just the top ,what make and model is the set and how old is the set?, it sounds to me like a vertical circuit failure but need more info plz.
Popular Solutions for Mitsubishi VS-60707 60 in.
Questions and Unsolved Problems for Mitsubishi VS-60707 60 in.
Do you recommend Mitsubishi VS-60707 60 in. Rear Projection Television?
Answer
Answer
I have a vs 60607 tv / input menu code is 1 2 lights come on for 1 sec then dim good audio
Answer
I have horizontal flickering lines that would come, and go. We blew the dust off the components with... (More)
Answer
will not turn on .lighting must have run in on it.fuse is good
Answer
vs-60707 mitsubishi horizontal line on screen moves to another location of the screen when the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi VS-60707 60 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
