Make sure you have your printer as the default printer. Next, right click on the icon and go to properties and select "Print Test Page" and that doesn't work then try different cables. Finally, if nothing else works completely remove and re-install printer software. Good luck and God bless.
My GX-6750 is not working well I just changed the ribbon and the letters and numbers are printed...
(More)
My GX-6750 is not working well I just changed the ribbon and the letters and numbers are printed dull and I also notice that the ribbon is not moving when I am typing
The left margin of my old IBM selectric is stuck way off to the right. How do I reset the left...
(More)
The left margin of my old IBM selectric is stuck way off to the right. How do I reset the left margin?
how do you read a ascii file created on a smith corona pwp365ds 3.5 in floppy on a pc with 3.5in...
(More)
how do you read a ascii file created on a smith corona pwp365ds 3.5 in floppy on a pc with 3.5in floppy. I can use dos 3.3 - 6.2 or windows 98,xp.
