How do I set up Linksys Wireless G Broadband Router with AT & T DSL services to logonon with my laptop? I just swicthed my services form Comcast. Linksys Wireless G Router Model WRT54G
It didn't work for me. Should the username be the email address from At&t that controls the DSL line, or should it be the username to get into the Netopia modem?
k so u moved to AT&T-DSL-so u have a user name and password right then the authendication method is different let me tell u the connection
AT&T-DSL-modem--->inter net port on the w/l router>and one of the ether net port on the router to ur pc(or)laptop>
and open an explorer browser screen on the pc and in the address bar type-192.168.1.1>hit enter>and
user name-- admin (lower case)
password-- admin (lower case)
and u can see the setup screen>
there change the (Automatic Configuration -DHCP)--to PPPOE
u can see a different screen where u need to enter the USER NAME >AND PASSWORD WHICH U GOT FROM UR AT&T
AND CLICK ON SAVE SETTINGS>AND REBOOT THE ROUTER AND MODEM>AND U CAN ACCESS INTER NET AND IF U WANT TO USE WIRE LESS GO TO THE SAME SCREEN LIKE 192.168.1.1>WITH USER NAME AND PASSWORD AND GO TO WIRE LESS SETTINGS AND CONFIGURE IT
rate me solved if its help thx
Was this helpful?
Yes
No
Solution #3
posted on Sep 30, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You need to set your Netopia for "Bridge Ethernet"
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
ps3 wont conect to friends on maden 10 is wired derect to the modem and still reading nat 3 what do...
(More)
ps3 wont conect to friends on maden 10 is wired derect to the modem and still reading nat 3 what do i do?
I have a e-machine d3123 and I bought a cradlepoint350 to get a wifi for the house and the e machine...
(More)
I have a e-machine d3123 and I bought a cradlepoint350 to get a wifi for the house and the e machine will not connect what do I need to do?
