Question about Nintendo Super NES Console
Picture but no Sound
I have had my SNES for a long time now. Working properly for as long as I've had it. And now I have no sound but everything else is working fine. I've tried more than one Video Cable. And a RF Switch just to be sure. And nothing. I hope someone can help me with my problem. Thanks.
I had the same problem, then I switched to the multi-out port (you can use a gamecube video cable). And now mine works fine
Posted on Dec 23, 2007
  • 328 Answers
Its a common problem with those old machines. You can open it up and re solder the input connection and check the circuits to see if any others need the same treatment. If you are not confident doing this, I am sure that it can be done cheap by someone qualified if you look around a little.
Posted on Nov 04, 2007
There is no sound with black screen
depending on how much you leave your TV on, it could be that internal chips could have fried and needs a tech to replace parts for picture and audio from manufacture.
Dec 18, 2012 | Sansui 19 in. LCD TV
When I hook up my SNES there is no picture - what do I do?
Well onlhy use the old consoles on CRT tv styles then.
Apr 08, 2012 | Nintendo Super NES Console
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
FC twin will not play SNES games. produces sound only
Try cleaning the cartridges, DON'T USE RUBBING ALCOHOL!!!!!! This can ruin the cartridge, there is a cleaner that you used to be able to buy (haven't look for one in a while). Check with your local game store or on ebay.
Mar 05, 2010 | YOBO Fc Twin Console
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
Vertical lines show up on my SNES picture of any game.
Do you have a third party AC adapter for it? If you aren't using the original one, check its voltage. Mine was a 9V instead of a 10V and while it allowed the machine to run, I got visual distortion effects similar to what you describe. If it isn't a 10V adapter, go to Amazon and get a real one instead of a cheap third party one. I got this one ( and it works great!
Mar 16, 2009 | Nintendo Super NES Console
I would suggest that you make sure the RCA jacks are hook up properly, and on the right color.If that doesn't fix it, then its an inside problem.It might need some cleaning.
Oct 05, 2007 | Nintendo NES Console
Nintendo Super NES Console Logo
139 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
