SOURCE: honda cr 125 new top end rebuild started ok but
sounds like the float in the carb is stuck or set to the wrong hight give the carb a few taps with a screwdriver if that dont work take the carb off and check the float and needle.
SOURCE: I have a 2000 1200 custom sportster. It leaks oil
if the oil tank is above the crank case,
inspect the oil pump check valve. go online and study the check valve's functional purpose and see to it that the vale is operating properly. it should not be an expensive fix.
if you reroute hose be carefull of rear tire annnd what does the oil level in the oil tank sit at when full and after the leak happens after -say a day of riding- a week
SOURCE: I have oil leaking out of the transmission
1 quart of oil into the primary. 2.8 quarts in the engine.
SOURCE: 2000 yamaha ttr90 fuel leaking out overflow tube
your float is stuck take carburator off and clean wiggle float and it shouldnt leak gas anymore
SOURCE: hose coming out of the bottom of the carburetor of
Probably just an overflow hose from the carb. If the float gets stuck or gummed up, too much fuel will go in the carb and come out, the hose routes the excess fuel away from the hot cylinders, etc and to the ground.
