If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Your convergence ic's need replaced. These are mounted on a long silver aluminum heat sink. The part numbers will begin with STK. You will have to unsolder these, so I hope your versed in this area. If not, the average price is $250.00 to replace.
If the picture was good prior to the 3D images, I would fix it. The convergence ICs either have poor connections or are defective. The IC is an STK392-110. There may be 2 inside the set. If you have this repaired, expect a labor cost in the $200 range. Request that the ICs be replaced rather than the board changed. This will maintain all of the internal settings and require only part replacement not a complete re-convergence adjustment.
bad convergence amp ic http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html Sony Convergence http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/ http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night
my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
It is hard to see, but it looks like your red color has shifted to the right. In most projection sets there are 2 large convergence IC's which put the 3 colors exactly where they are supposed to be on the screen. When one color is way off, giving the 3D effect, and you are unable to line the colors up using the convergence menu, it means that one of the convergence IC's has burned out. This is one of the most common failures in standard projection sets. The burned out IC should be replaced and the convergence circuits realigned by a qualified tech familiar with projection sets.
