Question about HP Compaq Presario V2000 Notebook
Screen brighter compaq 8510p
What button on ther keyboard makes the screen brighter
    Top Expert:
  • HP Master
  • 14,162 Answers
how to video
Posted on Dec 16, 2014
4 Suggested Answers
SOURCE:
micromend
  • 748 Answers
SOURCE: Dark screen if unhooked from battery
You can use the function keys to increase the brightness. Also if you go to Start, Control Panel, Power Options you can change the settings to give you more monitor time.
Posted on Apr 15, 2009
parrotheadpc
  • 2600 Answers
SOURCE: why has screen gone black
Sounds like either your backlight bulb has failed or the inverter that powers the bulb has failed or a connection has come loose from the inverter to the LCD panel. Unless the laptop was "Jarred" or dropped, I doubt the bulb has burned out....most likely if no damage occued, the inverter has failed or there is a loose connection with the inverter.
Posted on Jun 30, 2010
Geekman
  • 32281 Answers
SOURCE: power-on password on hp 8510p
Power On Password & Hard Disk Password
With your next laptop you should protect it with a Power On Password AND put a password on your hard disk. This will stop anyone from using your laptop and if they move the hard disk from your laptop to another laptop they cannot access the data on your hard disk with the hard disk password.
BUT you need to write down or remember these passwords; if you lose or forget them you cannot gain access to your laptop.
There are no backdoor passwords to remove these passwords.
To set up or change these passwords, go to the BIOS configuration - then security configuration. http://techtips.salon.com/reset-hp-laptop-bios-password-1476.html
Posted on Nov 27, 2012
HP/Compaq 8510p laptop, 5, 6, ?, and apostrophe not working. Also the little blue mouse in the middle of the keyboard not working. Everything else works. I ideas anyone?
Find instructions how to disassemble the keyboard, and check the plug or cable. Also make sure there is no debris in the keyboard under the keys. If these things don't work, you can find a replacement keyboard which would not be expensive.
Apr 22, 2014 | Computers & Internet
The screen wont light up on my compaq nc6230. you can just barely see the icons because the screen is not lit up. can i turn the back screen light on or is it damaged and need to be replaced
There is a screen brightness function on your keyboard, press the Fn key and the appropriate number key with a picture of a screen or sun on it. There will be two, one brighter the other darker.
If that doesn't work, you've probably got an inverter fault, or the ribbon connector has come adrift.
Different with most laptops but, remove power and batteries, check between the keyboard and the screen, there could be a plate which is clipped/screwed into place. Remove any screws and, very carefully, prise the plate off.
Look for ribbon connectors and make sure they are home and sound.
If one was loose, you've possible resolved the problem, if not, then you'll have to get it replaced.
Sep 12, 2010 | HP Compaq nc6230 Notebook
Why has screen gone black on compaq 8510p. Can vaguely see print
Jun 30, 2010 | HP Compaq 8510p Notebook
Is there a wireless hardswitch somewhere on HP Compaq 8510p
There is a wireless button the computer..
Its couple of inches beside the power key...
or the place where we have the HP logo...down below that there would be wireless Button/LED
Hope this works
Regards
KEN
May 11, 2010 | HP Compaq 8510p Notebook
I need to swich to external screen, keyboard and
Use the key combination 'Fn' and 'F10'..
Else use the key combination 'Fn' and the funtion key which has a monitor symbol printed on it.
please come abck and vote for me if this helps you or also if you need more clarification. Thnx
Mar 28, 2010 | HP Compaq 8510p Notebook
Yes there is a wireless hardswitch on this machine it is 2 to the right of the power button once pressed on the bottom left of the machine an led should light up so you know its activated
Mar 18, 2010 | HP Compaq 8510p Notebook
Lighten screen
while holding the fn key (function) press the f8 key a few times, screen brightness should get brighter with each press. the fn key might be located next to the control key lower right corner of keyboard.
Dec 25, 2009 | Compaq Computers & Internet
Apr 15, 2009 | HP Compaq Presario R4000 Notebook
Used Compaq Laptop screen not bright
Usually most laptops has blue/white function keys top on keyboard they can be used together with Fn button that is left bottom side of keyboard. For example on my laptop with F4 and F5 together with Fn can adjust brightness.
Best wishes,
Chillimar
Jan 27, 2009 | Compaq Presario Notebook
HP Compaq Presario V2000 Notebook Logo
296 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
