Question about Xerox WorkCentre XD120F Laser Printer
Found problem want to figure out how to repair
The copier guy was correct, the heat roller on my xerox xd120f was broken
Do I need to replace the whole heat roller assmebly or is the gear section replaceable.
I have the heat unit out of the machine
  • Anonymous Mar 24, 2008
    my fuser gear is broken i have the replacement and i need instructions to install
  • Anonymous Jan 31, 2009
    I purchased the heat roller gear. How do you install it? It just sit loosely. Does it snap in or am I missing another part?
    Novelist:
  • 208 Answers
If the gear is broken it can be replaced.
If you want to E-mail me at rak458@aol.com I can give you someone to contact to order that gear.
Its pretty cheap.
Posted on Dec 04, 2007
I have the Xerox XD120f. Cannot pull paper from either drawer.
The rollers are either dirty , or most likely worn out and need to be replaced. They are not hard to replace, but humidity is not the problem, the condtion of the rollers is the problem. Try cleaning them with something like fantastic or formula 109, then clean again with alcohol.
They become slick and will not feed paper. You can google a business called The Parts Drop, they carry about everything for Xerox copiers.
Feb 15, 2010 | Xerox WorkCentre XD120F Laser Printer
Xerox XD120F copy machine not pulling paper through to make a copy. Might grab paper and then jamb.
If the paper is not pulling out of the tray, you should replace the feed rollers. They are easy to replace.
If it is pulling the paper about 2/3 of the way through the machine, you would most likely have a broken fuser heat roll gear, again cheap and easy to replace.
Feb 15, 2010 | Xerox WorkCentre XD120f Copier
There should be a small metal ring that clips behind the roller.
Has it fallen into the machine ?
Jan 31, 2009 | Xerox CopyCentre C123 Copier
Xerox xd120f showing error code E7 and not copying
I had E7 and the unit required a new laser unit. Precision Roller had the replacement laser, which did correct the error. Apparently, during a move to a new location, something jarred the machine and caused the failure.
Oct 06, 2008 | Xerox Office Equipment & Supplies
Laser copy blotches, XD120f
Its your drum or fuser rollers
Jun 23, 2008 | Xerox WorkCentre XD120f Copier
When photocopying, a copy is made however the text also appears faintly in the background. (Model no: Xerox WorkCentre XD120F)
That would be either a bad heat roll or pressure roll.
In the area where the copy exits, the hot fuser area, eithet the heat roller, TOP roll or pressure roller, Bottom red roller are worn.
Easiest thing would be to replace the fuser.
Contact this parts reseller.
https://www.partsdrop.com/store/
Apr 21, 2008 | Office Equipment & Supplies
XEROX Workcenter XD120F
There are connectors that must be plugged in to the board to make them operate. Does the machine recognize that the trays are present? If it does see that the trays are there, I would suspect that with the age of the machine, both sets of feed rolls are either very dirty or in need of replacment. Most likely the rollers are just slipping on the paper when trying to feed. Clean them first with some soapy like cleaner, such as Fantastic, or just rubbing alcohol.
I really suspect bad or dirty rollers.
Feb 17, 2008 | Xerox WorkCentre XD120F Laser Printer
Paper in copier hangs up
it sounds like the heat roller gear has broken. open machine and look @ the heat section in the back you should see the gear broke.
Nov 04, 2007 | Xerox WorkCentre XD120f Copier
Drivers to windows vista no are in plans to devenlopment in xerox
Drivers for this printer can be found HERE: --> http://www.support.xerox.com/go/SOHO.asp?Xtype=download&prodID=XD120f&Xlang=en_US&Xcntry=USA ...or HERE: --> http://drivers.softpedia.com/get/PRINTER/XEROX/XEROX-Printer-WorkCentre-XD120f-501230001.shtml
Aug 03, 2007 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre XD120F Laser Printer Logo
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
