Question about Compaq Armada M700 Notebook
Compaq Armada M700 screen dim
Hi the laptop screen is very dim i pluged in an other montor and its fine how do i turn up thebrightness an u help plz
  • 117 Answers
Re: Compaq Armada M700 screen dim - Compaq Armada M700 Notebook PC Laptops
I think your inverter problem
Posted on Nov 05, 2007
0 characters
3 Points
How do i get to the recovery partion on compaq armada m700
Dear Lizanne,
To get to the recovery partition on your Compaq Armada M700, turn on the notebook and press F11 repeatedly until "Windows is loading files..." displays on the screen. Then, follow the on-screen instructions.
If your notebook originally came with Windows XP or an earlier version of Windows, try pressing F10 to enter recovery instead of F11.
Hope you may find these instructions useful!
Best regards,
Miguel L. Martins
May 16, 2014 | Compaq Armada M700 Notebook
How will I know if my laptop Compaq Armada m700 is fully charged already?
You do not say which operating system you are using.
Right click on the toolbar at the bottom of the screen > properties > notification area > tick the Power under System Icons - Select Which Items to always show > Apply > OK > float the mouse on the battery icon to see % of charge and charge time remaining.
I hope this helps.
Aug 24, 2011 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
The screem has broken and it can not power on
well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
May 23, 2008 | Compaq Armada M700 Notebook
Compaq armada m700 wont power up all the way
Sounds like you may have a problem with the internal power supply box? I am not sure but that may be at least something for you to have checked out. If the fan is not spinning this is usually a sign this may be what the problem is. GOOD LUCK!
May 13, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700, Dim Screen
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
May 07, 2008 | Compaq Armada M700 Notebook
Dim Screen
in the power saving options the screen may have been put down to save charge!
Apr 15, 2008 | Compaq Armada M700 Notebook
My Screen Is Black When I turn the Laptop On
need a inverter maybe. t23 lcd inverter check ebay diy project need a screw driver thats it
Apr 14, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Keys arent working
are they #s instead hit fn try to get latest driver for it from site make sure its pluged in tight under it if u know how
Feb 04, 2008 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
