How can i make the canon p126-d adding machine print? it does the calculation but will not print - the ribbon has been changed
SOURCE: need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
SOURCE: How do you load the adding machine paper on this
Paper loads into slot at end of machine. After inserting end into the slot (at rear, near power cord connection) press feed button until paper advance thru top.
