Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
What is the cubic ft of kenmore washer he3. Model 110.45862-400
I can't find out what the cubic ft of my drum in my front load washer anywhere. Looked in the manual and online. Please help. I am buy new ones and need to know if should go bigger than what I have now. It's a kenmore elite HE3 model number 110.45862-400.
  • 3 Answers
Per the title of the post, I believe that all HE3 washing machines are 3.8 cu ft.
"Problem with Kenmore 3.8 cu. ft. HE3 Front Load Washer"
Posted on May 22, 2014
    New Friend:
8 cuft3.
SOURCE:
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
SOURCE: Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Had same problem. Followed advice on post (i.e., remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter and voila!). Found one sock, a quarter, and some other junk clogging the drain. Saved $55 house service call. Thanks all!
Posted on Dec 13, 2007
SOURCE: Kenmore Elite HE3 washer
I found when mine doesn't drain there is a sock blocking the drain holes. Open the door and pull out the rubber gasket at the bottoma nd there should be around a half a dozen holes. Good luck!
Posted on Feb 21, 2008
SOURCE: Kenmore HE3 WasherManual?
Unplug the washer from its power source for safety. Then, open the panel under the washer door...you'll need a special type of screwdriver to remove the screws below the panel. Once you have the panel off, you'll find a technicians manual neatly taped to the inside right hand wall.
Posted on Aug 25, 2008
  • 4090 Answers
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Aug 01, 2009
What is the cu ft of the drum
Shirley, you answered your own question.
Kenmore (((((3.8 cu. ft.))))) HE3 Front Load Washer
3.8 cu ft. drum
Feb 21, 2016 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How many cubic feet is the frigidaire FSE447GHS0 front load washing machine
Good Afternoon friend, thank you for your post!
From the information you have provided you need to know the cubic footage of your Frigidaire washer, FSE447GHS0. I have researched your model and it appears to be 4.4 cubic ft. I hope this information is helpful to some degree. -Matt
Feb 25, 2015 | Frigidaire Refrigerators
I want a manual for My Kenmore HE4T Front Load Washer
This site has lots of manuals. http://www.manualslib.com/products/Kenmore-He4t-110-4508-3024385.html#.VPmnI5cyiQE.mailto
Feb 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
How large is the drum in this washer? I'm buying a new one and want to get one as large as my old one.
Get online, Type in the name brand and model number and hit enter. the should be relevant details about the product think there in cubic feet.most are around four i think. Hope that helped
Sep 21, 2013 | Kenmore 26882 Top Load Washer
What is the cubic size please is it. 4.0 of the 42832 it does not say anywhere in the book or on the machine or online.
To find the cubic volume, get a tape measure or yardstick. Measure from the back of the tub to thee front lip, note the inches. Then measure the diameter of the tub, top to bottom of door should be close.
Multiply the 2 measurements. Divide the product by 144. the result will give you cubic feet.
EXAMPLE: back to front of tub 30 inches X 20 inches diameter of tub = 4.16 cubic feet of space..
Jan 11, 2011 | Kenmore 42822 Front Load Washer
Sounds like a bangin when its in spin cycle need help please
If this is a front loading washer, the spider arm is broken at the back of the drum. Big bucks to repair this. You might as well buy a new machine.
May 23, 2009 | Frigidaire Gallery Supreme Series...
Front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Jan 02, 2009 | Frigidaire GLTR1670A Front Load Washer
LG Dishwasher 4.0 cubic feet Leaking from underneath the front door
Maybe you should get someone to patch it,.. or you could just get a new one,..
May 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
996 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
