Question about HP Vectra VL420 PC Desktop
Hewlett packard vectra vl420 mt 3 melodies music 3 beep
What the symptoms?
    Problem Solver:
  • 5 Answers
Sometime pc no give any error but there is problem.such as monitor,power problem and many more.
Posted on Jul 03, 2009
  • Dharambir Singh Jul 03, 2009
    3 short beeps means ram problem.
    3 long beeps means keyboard problem.
    1 short & 2 long cpu problem.
SOURCE:
My Hewlett Packard Vectra VL PC has two usb ports but doesn't seem to have a driver.
Hello Vivian Elliott,
Without USB drivers the USB port will not get detected so install the suitable drivers of your motherboard. As you've said that yours PC is HP Vectra VL PC but u didnt mentioned the actual motherboard manufacturer and the operating system your using.
So once open the below link and select your operating system and download the suitable drivers.
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome?sp4ts.oid=16361&ac.admitted=1397900160516.876444892.492883150
If this solution solves your problem vote me.
Regards,
Ravi Teja.M
Mar 21, 2013 | HEWLETT-PACKARD Computers & Internet
Cannot display on monitor
If your PC gives single normal beep while booting then try connecting your monitor to another working PC. If it doesn't display then check the VGA cable by replacing it with new one. If the beep is not normal then tell us the beep behaviour.
Nov 30, 2011 | HP Vectra VL420 Desktop PC - Intel Pentium...
Salve vorrei i driver aggiornati per il mio Vectra VL420 hp
you can download drivers on this page
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=45011&lang=en&cc=us&prodTypeId=12454&prodSeriesId=45010&taskId=135
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Vectra VL420 PC Desktop
Dont have sound on my pc!!HP Vectra VL400
You will need to re-install the sound drivers. You can download them here.
Just select your operating system from the list.
Feb 16, 2011 | HEWLETT-PACKARD HP Vectra XU 5/xx SCSI...
I just got this Vectra VL420 from a surplus store. I try to start up I get this funny music and then two beeps. I understand two beeps indicate power problems. But not sure what to do to rectify this....
From memory I would say you are in the right ball park.
I remember now. Error 2 means the power supply is in protect mode.
First check the wiring going to the Motherboard from the PSU. There is a four pin connector that lets the PSU know if all is well with the main board. If that is not connected, that may cause your problem
Try a new PSU. They are fairly cheap. Match the power on the specification panel stuck to the PSU.
If those don't fix it, a new motherboard is the next step.
Hope this helps.
Nov 22, 2010 | HP Vectra VL420 PC Desktop
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
HP AMD Desktop beep noise
HP BIOS beep codes
http://welcome.hp.com/country/us/eng/support.html
Because Hewlett-Packard (HP) uses a variety of motherboards and BIOSs, their computers use a variety of beep codes. Instead of listing each model's beep codes, links are provided to the support pages of several popular Hewlett-Packard desktops.
Note: Hewlett-Packard and Compaq merged in 2002 and the new company dropped the Compaq name from all but a few consumer product lines--such as Presario desktops and notebooks. This table lists only HP-branded desktops, while the next table lists Compaq-branded machines.
Model
System codes and messages link
e-PC c10/s10
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis13707
Kayak
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis06334
Kayak XM600
http://h20000.www2.hp.com/bc/docs/support/SupportManual/lpv07804/lpv07804.pdf
Kayak XU800
HP Multimedia PC series
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph01686
Pavilion Desktops with Phoenix BIOS
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph07107
Pavilion 5010, 5030, and 5040
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph01004
Pavilion 7xxx (7010, 7020, 7030, 7050, and possibly others)
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph01053
Vectra PCs with Phoenix BIOS (VL4, VL5, VL7, VL8, VLi8, VE2, VE3, VEi7, XM4, XA5, and possibly others)
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpv03305
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis06108
e-Vectra
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis06446
Vectra VE 5/xxx Series 4
http://h200004.www2.hp.com/bc/docs/support/SupportManual/bpv03974/bpv03974.pdf
Vectra VL600
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis01866
Vectra XA5
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis06112
Vectra XA 5/XXX
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpv03314
Vectra XE310
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis13051
Workstation i2000
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=tis07621
Workstation xw3100
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00038866
Compaq (Hewlett-Packard)
http://h10025.www1.hp.com/ewfrf/wc/siteHomeC?lc=en&cc=us
Because Compaq uses a variety of motherboards and BIOSs, their computers use a variety of beep codes. Instead of listing each model's beep codes, links are provided to support documentation for several popular Compaq desktops.
Note: Hewlett-Packard and Compaq merged in 2002 and the new company dropped the Compaq name from all but a few consumer product lines--such as Presario desktops and notebooks. Official Compaq support documentation is difficult to find on HPs Web site.
Model
Business Desktop d330 and d530
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00274415
Multiple Models
http://forums1.itrc.hp.com/service/forums/questionanswer.do?admit=716493758+1107879885254+28353475&threadId=222666
Oct 29, 2008 | HP Pavilion Media Center a1330n - AMD...
The PC doesn't work
I know this is about a year later but I just had the same problem too last night.
When you turn on the PC it plays this crazy tone music right? If so, listen to it then at the end you will hear a couple of beeps. In my case my system beep twice at the end. 2 beeps for me indicated Power supply was in protected mode. Luckly I had a spare P4 PS laying around which solved the problem.
If you have different beep code google up "HP Vectra VL420 Beep Code". Standard beep code doesn't apply to this mobo since the BIOS is customized.
My power supply was a standard P4 ATX... no special design from HP you should be able to get one at any computer store. Beware just don't the cheapest one it cuz they aren't build to last and aren't reliable. Trust me I've seen too many people buying cheap power supplies and having them kill their mobo's.
Apr 23, 2007 | HP P5750-69001 - System Board/P4...
HP Vectra VL420 PC Desktop Logo
667 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
