Write to them.
Testimonial: "They told me they don't have anything for the older obsolete models, like my electric motor based model."
Consider taking apart the pump and look for blockage, or see if the pump can be matched and replaced.
I turned it on its side so the ports were vertical, poured white vinegar in the ports and let it sit overnight, and tried it the next day and it worked better than ever. Evidently the vinegar disolved mineral deposits that were clogging things.
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
