SOURCE: 1992 toyota corolla
Sorry, was not available at your time. Since the blue light comes on, this tells me that the hi-beam fuse is good. Go to the pass side headlamp, and, behind it, remove the connector for the inop bulb, and remove the bulb. Examine the filament on the bulb. Is it broken in half? If so, you need two hi-beam bulbs. Get back to me if you need more info.
SOURCE: 1992 toyota Corolla Temp gauge does not work
find the wire that goes to temp sender and apply earth to it turn ignition on the temp gauge should read hot if it does replace water temp sender if gauge dose not move gauge needs replaging
SOURCE: 1992 Toyota Corolla CV Joint
You can pick up an entire re manufactured axle assembly at your local auto parts store. In order to replace the assembly you will need to disconnect the tie rod end and the ball joint. Remove the spindle nut. Push the axle stub out of the hub. Now with a suitable container under the axle to catch spilled fluid pry the axle from the transmission housing. Install is the reverse of removal. For more detailed instructions and diagrams go to www.autozone.com vehicle repair guides.
SOURCE: what's the spark plug gap for a toyota corolla 1.6 1992
If you are using iridium plugs or bosch supper 4 ytou don't usually need to mess with the gap. Standard plugs should be set at 0.032"
